Safe amount of boost to run on an S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Mar 29, 2005 2:24 pm
can anyone tell me what a safe amount of boost would be on an S4 with K04 turbo's.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
KayGee
RE: Safe amount of boost to run on an S4
Post by KayGee » Tue Mar 29, 2005 9:50 pm
Million dollar question.
1.3-1.2 seems fairly usual on an S4 (APR, MTM kits). However finding data is really hard. Very few dyno plots show boost against RPM. What does your AMD chip do?
I think the RS4 runs around 1.2-1.0 bar, it actually runs more boost higher up unlike the S4 which tapers off. Not sure what the chipped RS4s run. Hopefully someone from RS4 board will join in.
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Mar 30, 2005 8:09 am
Have been told that my car has been set on 20 PSI, but this seems a bit high to me. what do people think.
(20 PSI is 1.379 BAR ) I think
MING BLUE AUDI S4
Car is on Lock down
Mik
Post by Mik » Wed Mar 30, 2005 9:23 am
Brett
How much power are you getting from your remap with such a level of boost?
Mik
KayGee
Post by KayGee » Wed Mar 30, 2005 10:03 am
Doesn't sound OTT, if a RS4 runs 1.2 in std trim. Suspect that chipped RS4s run 1.4, I believe Verrukt runs 1.5 on his S4, although he has hybrids and flowed heads and cams.
Got any VAG com (003, 115) logs or Dyno runs?
KayGee
Post by KayGee » Wed Mar 30, 2005 10:23 am
Just realised in a couple of weeks our cars will be twins. Your K04 setup will be almost the same as mine. I'm having the RS4 oil cooler as well.
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Mar 30, 2005 12:07 pm
the car running 413.8bhp with 438.5 torque
MING BLUE AUDI S4
Car is on Lock down
dazzer
Post by dazzer » Wed Mar 30, 2005 12:23 pm
I believe NASA are good with rocket ships..... 8)
Dippy
Post by Dippy » Wed Mar 30, 2005 12:44 pm
If you guys don't have a boost gauge then I am amazed. I only have mild tuning compared to you and I wouldn't be without it.
1.4 bar is perfectly fine for K04s (as long as you have your APR bipipe!).
2001 Silver S4 Avant
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Mar 30, 2005 5:50 pm
Do have a boost gauge and APR bi-pipe, Goes to 20psi on launch then backs off to about 16 PSI I think.
MING BLUE AUDI S4
Car is on Lock down
Dippy
Post by Dippy » Thu Mar 31, 2005 2:12 pm
Get a metric one then ;)
That's the same as mine, so I suggest your map is conservative.
BRETTCOLLINS
Post by BRETTCOLLINS » Thu Mar 31, 2005 3:51 pm
Yes but 600 easy miles later and only kicked four times the engine blow up. not happy
MING BLUE AUDI S4
Car is on Lock down
jeffw
Post by jeffw » Thu Mar 31, 2005 4:00 pm
One who's Dyno ?
Out of interest what was your Wheel Horse Power and losses ?
KayGee
Post by KayGee » Thu Mar 31, 2005 5:20 pm
Do you know what happened to the engine yet? First S4 I have heard off that expired.
BRETTCOLLINS
Post by BRETTCOLLINS » Fri Apr 01, 2005 7:28 am
Not yet, But piston 6 with shot, no compression with 96% pressure loss.
MING BLUE AUDI S4
Car is on Lock down
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 57 guests
