Safe amount of boost to run on an S4
BRETTCOLLINS
- 5th Gear
can anyone tell me what a safe amount of boost would be on an S4 with K04 turbo's.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
RE: Safe amount of boost to run on an S4
Million dollar question.
1.3-1.2 seems fairly usual on an S4 (APR, MTM kits). However finding data is really hard. Very few dyno plots show boost against RPM. What does your AMD chip do?
I think the RS4 runs around 1.2-1.0 bar, it actually runs more boost higher up unlike the S4 which tapers off. Not sure what the chipped RS4s run. Hopefully someone from RS4 board will join in.
BRETTCOLLINS
- 5th Gear
Have been told that my car has been set on 20 PSI, but this seems a bit high to me. what do people think.
(20 PSI is 1.379 BAR ) I think
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
Brett
How much power are you getting from your remap with such a level of boost?
Mik
Mik
Doesn't sound OTT, if a RS4 runs 1.2 in std trim. Suspect that chipped RS4s run 1.4, I believe Verrukt runs 1.5 on his S4, although he has hybrids and flowed heads and cams.
Got any VAG com (003, 115) logs or Dyno runs?
Just realised in a couple of weeks our cars will be twins. Your K04 setup will be almost the same as mine. I'm having the RS4 oil cooler as well.
BRETTCOLLINS
- 5th Gear
the car running 413.8bhp with 438.5 torque
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
If you guys don't have a boost gauge then I am amazed. I only have mild tuning compared to you and I wouldn't be without it.
1.4 bar is perfectly fine for K04s (as long as you have your APR bipipe!).
2001 Silver S4 Avant
BRETTCOLLINS
- 5th Gear
Get a metric one then
That's the same as mine, so I suggest your map is conservative.
BRETTCOLLINS
- 5th Gear
Do you know what happened to the engine yet? First S4 I have heard off that expired.
BRETTCOLLINS
- 5th Gear
Users browsing this forum: Majestic-12 [Bot] and 57 guests
