The best oil
Tacko
The best oil
Post by Tacko » Tue Mar 03, 2015 5:12 pm
Hi all,
Just been to Audi Northampton to get the RS4 booked in for her service. Been quoted the usual crazy prices as expected (£184 for 9.6L of oil!). Anyway i'm having her serviced but have decided to provide my own oil. Was given the whole longlife oil story and that Audi's oil is recommended blah blah.... Just wandering what oil you guys recommend and if anyone knew a good supplier/website to order from?
Lee
2007 Daytona Grey Audi B7 RS4
toyneg
Re: The best oil
Post by toyneg » Tue Mar 03, 2015 5:31 pm
i use Catrol Edge in mine
Silverfox42
Re: The best oil
Post by Silverfox42 » Tue Mar 03, 2015 6:30 pm
2nd vote for Edge. Its the one Audi use and recommend.
Previous:
Tacko
Re: The best oil
Post by Tacko » Tue Mar 03, 2015 7:56 pm
Thanks for the help.
I have found this website selling Edge.
http://www.engineoildirect.co.uk/shop/4 ... tAodxD0A7Q
Good price i presume?
Re: The best oil
Post by MikeFish » Tue Mar 03, 2015 8:03 pm
I use castrol edge too.
But I'm pretty certain Audi always used to use Shell Helix before I started supplying my own own.
And didn't I read Castrol Edge is not a true fully synthetic oil?
NJMAudiRS4
Re: The best oil
Post by NJMAudiRS4 » Tue Mar 03, 2015 10:32 pm
I used Castrol Edge, then moved onto Fuchs Titan GT1, both Audi approved. Opie oils a site Sponsor stocks both
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
CellDamage
Re: The best oil
Post by CellDamage » Tue Mar 03, 2015 10:39 pm
There's also plenty of threads on this subject if you do a search ;)
KIQUE
Re: The best oil
Post by KIQUE » Wed Mar 04, 2015 11:17 am
I use 5w30 Castrol Edge Audi approved.
But next service I will use 10W40 ou 10W60 to reduce oil consumption.
JCviggen
Re: The best oil
Post by JCviggen » Wed Mar 04, 2015 2:59 pm
KIQUE wrote:next service I will use 10W40 ou 10W60 to reduce oil consumption.
On the German boards they all swear by Mobil 1 5w50 Peak Life for high oil consumption RS4s. That seems to solve it and the cars run well with it.
Would definitely not recommend 10w60 - its not an M3!
981 Cayman GTS Gray/Orange.
My youtube
KIQUE
Re: The best oil
Post by KIQUE » Wed Mar 04, 2015 4:37 pm
The RS4 use some oil at the first start, when the engine is cold (and also when it's hot at high revs ... OK ! )
So you may need to change the first grade "the cold one".
In the US, they use Liquy Molly 10W60 which seems very good :
JCviggen
Re: The best oil
Post by JCviggen » Wed Mar 04, 2015 8:03 pm
If you use your car for regular daily stuff a 60 weight is just really thick at 90C compared to what the engineers calculated. I'd rather use a lot of oil. I'd use it if I only tracked the car with 110C+
I don't believe in the "only uses oil when cold'' theory. It would be filling the street with thick blue smoke on cold starts if it had to use considerable amounts of oil in only the first minutes. Worn oil scraping rings don't suddenly get back into shape when they heat up either. High oil consumption on these engines is common and well documented, and many found the Mobil 1 oil to help massively. It's at least somewhat closer to spec.
My youtube
PetrolDave
Re: The best oil
Post by PetrolDave » Thu Mar 05, 2015 6:21 pm
The other thing that increases oil consumption is how far you've driven since the last oil change.
Over the years it's been well documented on here (and I've seen it personally too) that once you get past 5000 miles after an oil change the oil consumption definitely increases significantly (for me from almost zero to around 0.5 litre per 1000 miles). This is one of the reasons that some owners change their oil every 5000 miles.
JCviggen
Re: The best oil
Post by JCviggen » Thu Mar 05, 2015 6:47 pm
That is to be expected as oil loses viscosity over time/use. It literally gets thinner so it gets past the rings easier. Definitely why frequent oil changes on engines like these make sense, screw Audi's maintenance schedule and the long life BS.
My youtube
Tacko
Re: The best oil
Post by Tacko » Thu Mar 05, 2015 7:21 pm
Thanks for all your input i really appreciate it. I think i'm going to pick up some Castrol edge and change the oil every year/5k. According to Audi i wont need a service again for another 2 years after this one as the car only does 4-5k a year!!
neilparf
Re: The best oil
Post by neilparf » Fri Mar 06, 2015 3:40 am
Fusch Titan GT1 for me. It appears to get to temp quicker and runs slightly cooler...
Gone but never forgotten:
Users browsing this forum: Google [Bot] and 182 guests
