front brake pads
Acorn
front brake pads
Post by Acorn » Sun Feb 22, 2015 5:42 pm
Hi,
Need to replace the front pads soon any recommendations for other makes other than originals
Audi Pardner
Re: front brake pads
Post by Audi Pardner » Sun Feb 22, 2015 8:15 pm
The OEM pads are more than adequate in my view, unless you're doing track days etc. Don't know how they compare price wise to other makes though.
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
Lukes3
Post by Lukes3 » Sun Feb 22, 2015 8:55 pm
I use yellow stuff pads no problems so far.
Post by MikeFish » Sun Feb 22, 2015 8:57 pm
EBC yellow stuff are equal to or better than OEM in many peoples opinions and cost a lot less than OEM.
CycleSi
Post by CycleSi » Sun Feb 22, 2015 9:00 pm
I've recently fitted Redstuff Ceramic pads and they are excellent. No noise, very little dust and the same feel as OEM.
IMHO they're better than Yellowstuff.
SuprSi
Post by SuprSi » Sun Feb 22, 2015 9:03 pm
My yellowstuffs were good. I had them smoking profusely at Bruntingthorpe, a bit of fade from old fluid but the pads held out well.
andyg72
Post by andyg72 » Sun Feb 22, 2015 9:47 pm
CycleSi wrote:I've recently fitted Redstuff Ceramic pads and they are excellent. No noise, very little dust and the same feel as OEM.
hi cyclesi you say red stuff ceramic pads silly question for ceramic discs ?
CycleSi
Post by CycleSi » Mon Feb 23, 2015 12:25 am
EBC call them their Redstuff Ceramic pads but NOT because they are ceramic brakes as such, merely that they use some ceramic in the Redstuff compound.
They are for use with standard normal steel discs:
http://www.ebay.co.uk/itm/EBC-REDSTUFF- ... 0012486338
Divine
Post by Divine » Mon Feb 23, 2015 8:49 am
CycleSi wrote:EBC call them their Redstuff Ceramic pads but NOT because they are ceramic brakes as such, merely that they use some ceramic in the Redstuff compound.
Do you know if the R8 ones fit? Only reason I ask is they are the exact same part number and less than £150 http://www.ebay.co.uk/itm/AUDI-R8-4-2-4 ... 1c48587fcc
Harris.
Post by Harris. » Mon Feb 23, 2015 9:49 am
http://www.eurocarparts.com/ecp/c/Audi_ ... 51a&000036
Ive had these fitted about a month ago. Got to say there very good , Hardly any dust and work very well .
Divine
Post by Divine » Mon Feb 23, 2015 10:02 am
Harris. wrote:http://www.eurocarparts.com/ecp/c/Audi_ ... 51a&000036
I was looking at those. Is that £116.40 for all 8 fronts? TRW are a v.good OEM supplier.
Harris.
Post by Harris. » Mon Feb 23, 2015 10:33 am
Yeah I paid £111 for all 8 then £30 at fomula 1 to fit them as I don't do brakes . but as said they work very well .
Divine
Post by Divine » Mon Feb 23, 2015 11:26 am
Cheers. Need to get a ECP order this week so will buy some. Do you need wear sensors too?
Harris.
Post by Harris. » Mon Feb 23, 2015 11:27 am
They Come with the pads mate
RossDagley
Post by RossDagley » Mon Feb 23, 2015 12:51 pm
A good cheap pad is the ferodo premier pad - about £65 for a full front set. Worked fine for me as a stopgap until I went for Yellow Stuffs (which saw 2 track days and 3 'ring trips last year, and are still going strong).
Yellow stuffs all the way IMO.
Previously:
