front brake pads
front brake pads
Hi,
Need to replace the front pads soon any recommendations for other makes other than originals
Audi Pardner
Re: front brake pads
The OEM pads are more than adequate in my view, unless you're doing track days etc. Don't know how they compare price wise to other makes though.
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
I use yellow stuff pads no problems so far.
EBC yellow stuff are equal to or better than OEM in many peoples opinions and cost a lot less than OEM.
I've recently fitted Redstuff Ceramic pads and they are excellent. No noise, very little dust and the same feel as OEM.
IMHO they're better than Yellowstuff.
My yellowstuffs were good. I had them smoking profusely at Bruntingthorpe, a bit of fade from old fluid but the pads held out well.
hi cyclesi you say red stuff ceramic pads silly question for ceramic discs ?CycleSi wrote:I've recently fitted Redstuff Ceramic pads and they are excellent. No noise, very little dust and the same feel as OEM.
EBC call them their Redstuff Ceramic pads but NOT because they are ceramic brakes as such, merely that they use some ceramic in the Redstuff compound.
They are for use with standard normal steel discs:
http://www.ebay.co.uk/itm/EBC-REDSTUFF- ... 0012486338
Do you know if the R8 ones fit? Only reason I ask is they are the exact same part number and less than £150 http://www.ebay.co.uk/itm/AUDI-R8-4-2-4 ... 1c48587fccCycleSi wrote:EBC call them their Redstuff Ceramic pads but NOT because they are ceramic brakes as such, merely that they use some ceramic in the Redstuff compound.
http://www.eurocarparts.com/ecp/c/Audi_ ... 51a&000036
Ive had these fitted about a month ago. Got to say there very good , Hardly any dust and work very well .
I was looking at those. Is that £116.40 for all 8 fronts? TRW are a v.good OEM supplier.Harris. wrote:http://www.eurocarparts.com/ecp/c/Audi_ ... 51a&000036
Divine wrote:I was looking at those. Is that £116.40 for all 8 fronts? TRW are a v.good OEM supplier.Harris. wrote:http://www.eurocarparts.com/ecp/c/Audi_ ... 51a&000036
Yeah I paid £111 for all 8 then £30 at fomula 1 to fit them as I don't do brakes . but as said they work very well .
Cheers. Need to get a ECP order this week so will buy some. Do you need wear sensors too?Harris. wrote:Divine wrote:I was looking at those. Is that £116.40 for all 8 fronts? TRW are a v.good OEM supplier.Harris. wrote:http://www.eurocarparts.com/ecp/c/Audi_ ... 51a&000036
They Come with the pads mate
- RossDagley
- Top Gear
A good cheap pad is the ferodo premier pad - about £65 for a full front set. Worked fine for me as a stopgap until I went for Yellow Stuffs (which saw 2 track days and 3 'ring trips last year, and are still going strong).Harris. wrote:http://www.eurocarparts.com/ecp/c/Audi_ ... 51a&000036
Yellow stuffs all the way IMO.
Previously:
Previously:
