Tyre load rating dvice for those gone from 19 to 20
N11LS_J
Post by N11LS_J » Thu Jan 29, 2015 2:41 pm
Hey guys
My B7 OEM tyres were 96Y rated on the 255/35/19 however now going up to 20" wheels, I can't seem to find tyres higher than 92Y on 255/30/20
Or best I've found on 265/30/20 are 94Y
What have those you of you who have gone from 19" to 20" opted for?
Nils
Instagram : n_i_l_s
Re: Tyre load rating dvice for those gone from 19 to 20
Post by bam_bam » Thu Jan 29, 2015 4:05 pm
I 'think' the I've run a Yokohama 265/35/r20 with a 99Y. Quite a rounded tyre so they fit ok, if memory serves me. Best try some test fit/measuring.
I've also tracked GY F1s 255/35/r20 94Y stretched on 20x9.5s - they were actually really good and my car is probably heavier than yours.
N11LS_J
Post by N11LS_J » Thu Jan 29, 2015 4:34 pm
I'm hoping to go 255/30/20 on my 9j wheels so that's good to hear, I don't track mine either
Cheers Bam
:beerchug:
Instagram : n_i_l_s
geordie jay
Post by geordie jay » Thu Jan 29, 2015 4:40 pm
I run 92y on my 20".......no issues
bops4
Post by bops4 » Thu Jan 29, 2015 7:26 pm
Had the exact same dilemma on my c6 when i switched 19 to 20's. I'm running 255/30/20 on a 92y for a year now with no issues, my c6 must be way heavier so can't see a problem
Post by bam_bam » Thu Jan 29, 2015 8:34 pm
I thought the C6 ran 275 section, why you running 255s?
Post by MikeFish » Thu Jan 29, 2015 9:02 pm
I'm running 92Y XL on mine.
nij
Post by nij » Fri Jan 30, 2015 3:20 am
I'm running 265/30/20 94Y for two reasons, like you I can only find 92Y tyre load rating on 255/30 tyres and the 265/30s are a little closer at 94Y. Secondly, the speedometer reads more accurate with 265/30s.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
bops4
Post by bops4 » Fri Jan 30, 2015 6:38 am
bam_bam wrote:I thought the C6 ran 275 section, why you running 255s?
Coz its my daily oil burner
Post by bam_bam » Fri Jan 30, 2015 8:20 am
Ahhh.
classba
Post by classba » Fri Jan 30, 2015 12:18 pm
Bam, I think he is saying it's not an RS6 .
Post by bam_bam » Fri Jan 30, 2015 2:53 pm
Yeah. Hence my "ahhh". It's funny how we all just assume any post is referring to an RS.
Post by MikeFish » Fri Jan 30, 2015 7:53 pm
nij wrote:I'm running 265/30/20 94Y for two reasons, like you I can only find 92Y tyre load rating on 255/30 tyres and the 265/30s are a little closer at 94Y. Secondly, the speedometer reads more accurate with 265/30s.
My last set of tyres were 265/30/20and 94Y like you. But why do you say they are more accurate? 255/30/20 will read exactly the same as OEM tyres but 265 will introduce a slight error due to the size difference. Are you saying the OEM tyres are not the most accurate size?
nij
Post by nij » Sat Jan 31, 2015 3:37 am
I know the gearing will be slightly out, but what I ment was more accurate to the true speed you're travelling. Almost all speedos under read by about 10%, therefore when it reads 30mph, you're only really travelling at about 27mph. If you ever pass one of those "Your Speed" signs, you'll know what I mean. You could also check your Sat Nav speed in "Engineer Mode" in your RNS-E, which is more accurate and it isn't affected by tyre wear.
geordie jay
Post by geordie jay » Sat Jan 31, 2015 12:34 pm
haha when I pass those signs at 30mph it says 30mph???? sure your alloys aren't square fella :bash: :biggrin3:
Return to “General Car Chat”
