Surrey Rolling Road Day - Saturday 17th January 2015
bazza138
Re: Surrey Rolling Road Day - Saturday 17th January 2015
Post by bazza138 » Sat Jan 17, 2015 5:54 pm
RIV wrote:
that's a good handing car that is !!!
Gutted couldn't make it
:biggrin3:
What happened to you?
Working :( found out I was on call last week ! Chiswick , then Victoria
RIV
Post by RIV » Sat Jan 17, 2015 5:56 pm
Working found out I was on call last week ! Chiswick , then Victoria
Gutted!!
esp_mm-270
Post by esp_mm-270 » Sat Jan 17, 2015 5:56 pm
Doug_S2 wrote:you need the gearbox hot - I bet the more runs you do the power comes up - but then you have to be careful you don't heatsoak the engine and it makes less (proper pita for the turbo cars stopping heatsoak with multiple runs) the b8s usually do 420-440ps on our dyno
May well be but the other b8 did over 420 with winter tyres on (more drag it's said). The other thing, his dyno don't do wind down so are these figures whp? Still Doug, mine left you with 430 bhp and 330 lb/ft and after at least 17k miles since last carbon clean it's looking ok and all dyno's read slightly different of course :)
RIV
Post by RIV » Sat Jan 17, 2015 6:00 pm
I thought it was less 413?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Jan 17, 2015 6:01 pm
esp_mm-270 wrote:May well be but the other b8 did over 420 with winter tyres on (more drag it's said). The other thing, his dyno don't do wind down so are these figures whp? Still Doug, mine left you with 430 bhp and 330 lb/ft and after at least 17k miles since last carbon clean it's looking ok and all dyno's read slightly different of course :)
measuring rundown is just one more step to remove something that changes - the drivetrain losses with temps etc. someone should have logged every car and then you can justify the power and torque numbers each car does on the dyno.
http://www.MRCtuning.com
esp_mm-270
Post by esp_mm-270 » Sat Jan 17, 2015 6:02 pm
kent_andy wrote:Doug, graphs below. It's only done 250 miles since you tweaked it and it's still the same brute, just having to adjust driving style to this weather as it struggles to lay it down.
Just looking at ur figures and it's close to 5% different. Conditions? Dyno differences? Any who, add 5% to my result and I'm back to 430 :)
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat Jan 17, 2015 6:03 pm
winter tyres in my experience mean as much as 20ps less at the wheels.
esp_mm-270
Post by esp_mm-270 » Sat Jan 17, 2015 6:03 pm
Makes sense, ty :)
TechNick
Post by TechNick » Sat Jan 17, 2015 6:07 pm
kent_andy wrote:Love the picture!
This one may be better
...is it just my dodgy camera work, or is the plate slightly wonky?
RIV
Post by RIV » Sat Jan 17, 2015 6:09 pm
Plate straight, camera angel?
GrahamS4
Post by GrahamS4 » Sat Jan 17, 2015 6:11 pm
RIV wrote:Car was just ticking over for 5 mins before run
Roughly how long since it was driven before that?
RIV
Post by RIV » Sat Jan 17, 2015 6:12 pm
Around 1 hour
TechNick
Post by TechNick » Sat Jan 17, 2015 6:12 pm
Posted the wrong pic for a few seconds, then corrected it! ;-)
RIV
Post by RIV » Sat Jan 17, 2015 6:15 pm
Few!! Thought I had lost the plot :biggrin2:
TechNick
Post by TechNick » Sat Jan 17, 2015 6:19 pm
Doug_S2 wrote:
TechNick wrote:
kent_andy wrote:Dyno comparison wise i was 2% down compared to my Mrc run just before Xmas.
445HP vs. 490PS for me, but clearly not running at its best, judging by the air coming out of the back during the run.
charge coolers need to be super cool to start with or big power differences - still on same fuel? Charlie gets similar numbers to our on the b8s so something not right - and you didn't rev to 7200 limiter.
Yeah, still on fresh Momentum99, although had some VPower through the system previously (should have been long gone by the run, though, as emptied the tank right down then filled it with momentum and drove it for 150-odd miles a couple days prior to the run).
Yeah, something not quite right - I'll need to get it in to you for a health-check. :?
