S mode
4.2 V8 32v FSI - 444 bhp
bobbyRS
S mode
Post by bobbyRS » Sun Dec 28, 2014 4:06 pm
Hi. Hope this isn't a stupid question, if pop car in S mode via the gear stick, does that activate full dynamic mode for engine/gearbox or just gear shifts?
In my individual setting on ADS I've got dynamic mode for engine set but it doesn't always start in S mode on gear indicator - usually in D. Hope this makes sense!
Graeme4130
Re: S mode
Post by Graeme4130 » Sun Dec 28, 2014 6:37 pm
bobbyRS wrote:Hi. Hope this isn't a stupid question, if pop car in S mode via the gear stick, does that activate full dynamic mode for engine/gearbox or just gear shifts?
Hi Bobby
It'll always start in d
If you select S it'll just hold the gear longer and open up the exhaust valves if you have them in dynamic (the car will always start with them closed, but once you select S on the stick, they'll open, and stay open even if you re select D)
Hope that makes sense
Jezzer
Re: S mode
Post by Jezzer » Mon Dec 29, 2014 12:33 am
If I re select D on mine I thought the exhaust valves closed back up again
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
carsarecool
Re: S mode
Post by carsarecool » Mon Dec 29, 2014 10:17 am
Jezzer wrote:If I re select D on mine I thought the exhaust valves closed back up again
They won't when in Dynamic mode. They will close when selecting D in the other modes.
Revolution
Trader (Expired)
Re: S mode
Post by Revolution » Mon Dec 29, 2014 11:42 am
you could always set your individual car settings to have exhaust valves open and leave everything else in auto...
then it (should) start up with again in the last setting used..
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
Moonmonkey831
Re: S mode
Post by Moonmonkey831 » Mon Dec 29, 2014 1:07 pm
I have it set on individual for exhaust open, but I still have to press the drive select to go into dynamic and back again to individual or pull back into S and back again to D to open them. Seems it won't start up with the valves open.
Current: 2017 RS6 Performance in Nardo Grey
Previous: 2014 RS4 in Sepang Blue; 2011 Q5 3.0TDi Sline Plus in Ibis White; 2007 Audi S5 4.2 V8 in Phantom Black; 2006 VW Golf GTi in Tornado Red; 1998 VW Golf 1.9 TDi in Navy Blue; 1988 VW Polo 1.0 in Gold
carsarecool
Re: S mode
Post by carsarecool » Mon Dec 29, 2014 2:35 pm
Moonmonkey831 wrote:I have it set on individual for exhaust open, but I still have to press the drive select to go into dynamic and back again to individual or pull back into S and back again to D to open them. Seems it won't start up with the valves open.
Same.
eightfoot
Re: S mode
Post by eightfoot » Mon Dec 29, 2014 3:19 pm
i fixed this on mine by :bigblink: opening the boot lift the floor panel and look down on the left hand side at the vac ball then disconect the vac pipe that goes to the valves,valves now always open but dont forget to plug the pipe/ball :beerchug:
carsarecool
Re: S mode
Post by carsarecool » Mon Dec 29, 2014 7:54 pm
Can you not "crimp" the pipe with a cable tie, should have the same effect?
Users browsing this forum: Thedarkside and 106 guests
