Seen this has anyone used it all
http://www.evanscoolants.co.uk/power-co ... -cars.html
Anyone used this
Re: Anyone used this
Hi
our local Porsche indie sells this product..RPM technik.com.Maybe talk to them as they are all petrol heads and a top bunch of guys.
RS6 Grey and Loud.
B8 RS4 Daytona gone
B8 RS4 Daytona gone
- Shinobi675
- 5th Gear
I too can vouch for rpm. Great guys, they look after my 996 for its check ups
- RossDagley
- Top Gear
Yes. I used to use it on my peugoet 106. Very good stuff - personally seen it save another engine (Citroen AX) from overheating on the dyno when we didn't notice the engine wan wasn't working and the coolant temp crept up to 140 degrees. Track days don't like this stuff at all though - some even ban it. It's mighty slippery and flammable. Certainly wouldn't want a coolant leak onto a hot exhaust manifold.
Previously:
Previously:
Question is: do you really have a problem with overheating? Even on track, your brakes would melt well before you got the B7 to overheat. It's also said that the cooling system needs to be optimised/built for waterless coolant. There are a bunch of other reasons but unless it's a modified car running at WOT or close to it for long periods of time (like a drift car), then this is probably a massive overkill, if not pointless.
- RossDagley
- Top Gear
In my previous case, it was a 1.6 litre engine developing over 450hp so was highly strung.
As you elude to, it's probably not worth it in a 'standard' car, even an RS.
Previously:
Previously:
