Hesitation
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 4:38 pm
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Re: Hesitation
Post by Shoppinit » Sun Aug 24, 2014 4:46 pm
I don't believe the pump can generate any codes. The fuel pump controller module might though. Possibly you need to do some logs while driving to see what's happening to the mixture when the hesitation occurs.
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 5:50 pm
is it possible when looking at the mixture values i can see which pump it is? im pretty sure its a pump related sound. When cold it behaves normal.
i know there are two, one in the fuel tank beneath the rear seats, the other im not sure.
one is for sucking, one for pumping? dont know which sucker is in the fueltank though....
i can probably lift of the rear seat , if the noise gets a lot louder when im opening the lid, this should be the defect pump.
Yellow Koni's
Re: Hesitation
Post by Shoppinit » Sun Aug 24, 2014 5:55 pm
One is the lifter in the fuel tank which is low pressure high volume. This feeds the main pump which is higher pressure for the fuel injectors and is accessible from the outside. Difficult to tell which is the culprit without testing the fuel pressure.
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 6:01 pm
Shoppinit wrote:One is the lifter in the fuel tank which is low pressure high volume. This feeds the main pump which is higher pressure for the fuel injectors and is accessible from the outside. Difficult to tell which is the culprit without testing the fuel pressure.
...that makes sense.
where is the main pump located?
Yellow Koni's
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 6:06 pm
...probably in the fuelfilter area... :oops:
Yellow Koni's
Re: Hesitation
Post by Shoppinit » Sun Aug 24, 2014 6:09 pm
Why don't you pull up the back seat, expose the lifter pump top and have someone drive the car while you listen to the pump with a screwdriver on your ear to see if you can hear it stalling?
Re: Hesitation
Post by Shoppinit » Sun Aug 24, 2014 6:13 pm
Did you ever have the ECU checksum error come back?
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 6:38 pm
Shoppinit wrote:Why don't you pull up the back seat, expose the lifter pump top and have someone drive the car while you listen to the pump with a screwdriver on your ear to see if you can hear it stalling?
yep, thats what i was thinking. the sound is more present inside the car then outside. so it will probably the one inside the fueltank.
Thanks for the input Ben. :thumbs:
Yellow Koni's
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 6:39 pm
Shoppinit wrote:Did you ever have the ECU checksum error come back?
No, never came back. unless that warninglight is broken....
Yellow Koni's
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 6:41 pm
...will have a look at ebay, Audi is charging 400-500+ euros for the 4B0 906 087 BF part.
And ElsaWin is showing the tools 3087, 3307, T40020 are needed...
Yellow Koni's
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 7:19 pm
oh yes, i forgot to mention the gas filled strut from the 5th door is broken too...weird it goes all of a sudden...
Think only the left is gas filled.
Yellow Koni's
Re: Hesitation
Post by Shoppinit » Sun Aug 24, 2014 7:29 pm
At least that'll be relatively cheap to fix.
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 7:59 pm
Dont know how long the lines for the airbag and heaters are before i brutally get the rearseat out...
Yellow Koni's
Re: Hesitation
Post by Shoppinit » Sun Aug 24, 2014 10:26 pm
No airbags in the bench seat. Unless you have a clown car.
The heated seat wires are a faff. Forgot about those.
Users browsing this forum: Bing [Bot] and 145 guests
