Hesitation
Re: Hesitation
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Re: Hesitation
I don't believe the pump can generate any codes. The fuel pump controller module might though. Possibly you need to do some logs while driving to see what's happening to the mixture when the hesitation occurs.
Re: Hesitation
is it possible when looking at the mixture values i can see which pump it is? im pretty sure its a pump related sound. When cold it behaves normal.
i know there are two, one in the fuel tank beneath the rear seats, the other im not sure.
one is for sucking, one for pumping? dont know which sucker is in the fueltank though....
i can probably lift of the rear seat , if the noise gets a lot louder when im opening the lid, this should be the defect pump.
Yellow Koni's
Yellow Koni's
Re: Hesitation
One is the lifter in the fuel tank which is low pressure high volume. This feeds the main pump which is higher pressure for the fuel injectors and is accessible from the outside. Difficult to tell which is the culprit without testing the fuel pressure.
Re: Hesitation
...that makes sense.Shoppinit wrote:One is the lifter in the fuel tank which is low pressure high volume. This feeds the main pump which is higher pressure for the fuel injectors and is accessible from the outside. Difficult to tell which is the culprit without testing the fuel pressure.
where is the main pump located?
Yellow Koni's
Yellow Koni's
Re: Hesitation
...probably in the fuelfilter area...
Yellow Koni's
Yellow Koni's
Re: Hesitation
Why don't you pull up the back seat, expose the lifter pump top and have someone drive the car while you listen to the pump with a screwdriver on your ear to see if you can hear it stalling?
Re: Hesitation
Did you ever have the ECU checksum error come back?
Re: Hesitation
yep, thats what i was thinking. the sound is more present inside the car then outside. so it will probably the one inside the fueltank.Shoppinit wrote:Why don't you pull up the back seat, expose the lifter pump top and have someone drive the car while you listen to the pump with a screwdriver on your ear to see if you can hear it stalling?
Thanks for the input Ben.
Yellow Koni's
Yellow Koni's
Re: Hesitation
No, never came back. unless that warninglight is broken....Shoppinit wrote:Did you ever have the ECU checksum error come back?
Yellow Koni's
Yellow Koni's
Re: Hesitation
...will have a look at ebay, Audi is charging 400-500+ euros for the 4B0 906 087 BF part.
And ElsaWin is showing the tools 3087, 3307, T40020 are needed...
Yellow Koni's
Yellow Koni's
Re: Hesitation
oh yes, i forgot to mention the gas filled strut from the 5th door is broken too...weird it goes all of a sudden...
Think only the left is gas filled.
Yellow Koni's
Yellow Koni's
Re: Hesitation
At least that'll be relatively cheap to fix.
Re: Hesitation
Dont know how long the lines for the airbag and heaters are before i brutally get the rearseat out...
Yellow Koni's
Yellow Koni's
Re: Hesitation
No airbags in the bench seat. Unless you have a clown car.
The heated seat wires are a faff. Forgot about those.
Users browsing this forum: Google Adsense [Bot] and 99 guests
