RS4 Saloon 2008/08 38,476 Miles Exclusive Pack (A ONE OFF)
Re: RS4 Saloon 2008/08 38,476 Miles Exclusive Pack (A ONE OF
Lol.... And I bet someone will buy it and not find out it's an import
Yep. Only give away is the speedo in kmh and that ain't enough. The rest will 'appear' to be normal with registration style.
There's some greedy mo-fo's out there...
Gone but never forgotten:
Says service history in Dublin
Easy to change from km to miles just plug it in to vcdsneilparf wrote:Yep. Only give away is the speedo in kmh and that ain't enough. The rest will 'appear' to be normal with registration style.
Was a bargain at £24k
If I didn't have the R8 I would have bought this in a blink
Yeah, but do Parkway know that...PaulRS4 wrote:Easy to change from km to miles just plug it in to vcdsneilparf wrote:Yep. Only give away is the speedo in kmh and that ain't enough. The rest will 'appear' to be normal with registration style.
Either way, it's an import...PaulRS4 wrote:Says service history in Dublin
ReallyHYFR wrote:£24k
- Surrey Sam
neilparf wrote:Yeah, but do Parkway know that...PaulRS4 wrote:Easy to change from km to miles just plug it in to vcdsneilparf wrote:Yep. Only give away is the speedo in kmh and that ain't enough. The rest will 'appear' to be normal with registration style.
You can't change the speedo scale with VCDS, perhaps a slim chance with the odometer. According to a third party it's circa £900 to get a UK binnacle fitted by Audi.
You don't need VCDS at all for any of the digital conversions.Surrey Sam wrote:You can't change the speedo scale with VCDS, perhaps a slim chance with the odometer. According to a third party it's circa £900 to get a UK binnacle fitted by Audi.
To switch between MPH and KMH - the 'Units' in the DIS simply needs changing to MPH > KMH or vice versa and the odometer, trip and distance to next service is reclauclated. The only giveaway is the analogue speedometer - the inlay is primarily 'MPH' printed for the UK next to the higher end of the scale (180/200). The MPH scale is white with the secondary KMH in red. Non UK versions are primarily all white numerals with KMH being the larger and even the secondary MPH is white being the smaller numerals.
Sam, not sure you need a new binnacle fitted just new inlays, but even so, a bunch of work to change the inlays - unless Parkway have done this work (I doubt) to 'mask' accordingly and re-calibrated the speedo it would annoy the hell out of me personally...
Interestingly, non of the adverts show the cliché up close binnacle shots found in adverts - that would give it away. You can just make out the all white inlay and the 'KMH' at the TDC of the scale on the OP images...
- Attachments
- IMG_3235.JPG (98.64 KiB) Viewed 1312 times
- Surrey Sam
Neil, I don't believe KMH cars have the secondary scale so it'd need a new instrument cluster to read MPH, I imagine the temperature scale will also be in fahrenheit.neilparf wrote:Non UK versions are primarily all white numerals with KMH being the larger and even the secondary MPH is white being the smaller numerals.Surrey Sam wrote:You can't change the speedo scale with VCDS, perhaps a slim chance with the odometer. According to a third party it's circa £900 to get a UK binnacle fitted by Audi.
Best I could quickly find:
***Edit***
I'm wrong about the temp scale as looking at the above it's the same as all others (odd)?
but here is a better one of the Speedo
Sam - you are totally right. That image I got and highlighted above, was from the OP image. I assumed the smaller and larger numbers were a mix of MPH and KMH as I couldn't see the entire dial - good find.
If that's the case, thats even worse as there's no way of reading MPH on an open road and surely (from my days of Mitsubish Evo5 days) is non-MOT compliant?? How would you know how fast you are going on a UK road?
Resolve would surely be an inlay and re-calibration? I think inlays are available?
He's done bloody well to take a steady shot of the speedo at nearly 170mph!
- daytonamart
- 5th Gear
Oil looks hot too!!
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
Biggusguttus
For sale again for £34995 auto trader
Users browsing this forum: Squadr0n_ and 62 guests
