Hesitation
mavada
Re: Hesitation
Post by mavada » Mon Jul 07, 2014 3:34 pm
Started to take out the fuel filter, but cant get the number 3 out cos the nut on the other side is turning along with the bold and hits what i think is a drc pipe :audibash: tried some wd40 on it...
The space im working in wont help either...and dont like to work underneath with just my head.
Looks like the filter(Bosch) has never been replaced.
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Re: Hesitation
Post by bam_bam » Mon Jul 07, 2014 4:27 pm
Wow, you've got more than enough space to work in that garage, not sure what you're complaining about.
ahoooga
Re: Hesitation
Post by ahoooga » Mon Jul 07, 2014 5:19 pm
LOL :jump_clap:
SuprSi
Re: Hesitation
Post by SuprSi » Mon Jul 07, 2014 7:21 pm
That's impressive!
amanda1
Re: Hesitation
Post by amanda1 » Mon Jul 07, 2014 7:27 pm
Ohhh stop wingeing mav .....you have enough room for a jack :bigblink:
950 nm torque!
Nobby
Re: Hesitation
Post by Nobby » Mon Jul 07, 2014 9:52 pm
You still struggling Mav?
I just did mine and like last time I just removed the clips on one side of the filter (out) then removed the pipe from the pump out too. Then just the jubilee clip on the filter itself (put some clamps in the pipes either side too so you don't lose tooth fuel)
Daytona RS6 Avant
mavada
Re: Hesitation
Post by mavada » Mon Jul 07, 2014 10:18 pm
yeah i could try that, cant get the bold tightened anymore...
You probably did it on a ramp, on jackstands its terrible.
Yellow Koni's
Nobby
Re: Hesitation
Post by Nobby » Tue Jul 08, 2014 9:16 am
Nope, on the driveway. One jack and an axle stand.
Daytona RS6 Avant
mavada
Re: Hesitation
Post by mavada » Tue Jul 08, 2014 9:16 pm
i just hate working under my car cos i can hardly focus on the stuff cos its just some 20 cm above my face, cant get the car higher then this...
Is it under lots of pressure? How much fuel is coming with it when i cant use clamps?
Yellow Koni's
mavada
Re: Hesitation
Post by mavada » Wed Jul 09, 2014 9:01 pm
...old bastard is out.
Yellow Koni's
Re: Hesitation
Post by bam_bam » Wed Jul 09, 2014 9:20 pm
Wow, frame it.
Nobby
Re: Hesitation
Post by Nobby » Wed Jul 09, 2014 10:11 pm
Cut it open, mine was black inside after only 1 year!
Daytona RS6 Avant
mavada
Re: Hesitation
Post by mavada » Thu Jul 10, 2014 7:20 pm
yeah will try that.
Does it build op pressure when i turn ignition on? or does it take a while to start the engine?
Yellow Koni's
Nobby
Re: Hesitation
Post by Nobby » Thu Jul 10, 2014 10:51 pm
Turn in the ignition and it should prime. . Turn it off then do it again. It might turn over for a few seconds but should start almost straight away.
Daytona RS6 Avant
mavada
Re: Hesitation
Post by mavada » Sun Aug 24, 2014 3:22 pm
Unfortunately the new fuelfilter didnt solve it, still making odd noises from the rear wheel area now and then.
So next step would be one of the fuelpumps... :( no DIY im afraid...
Will the fuelpump throw up codes? beside the starvation of fuel to the engine on full throttle?
Yellow Koni's
Users browsing this forum: Majestic-12 [Bot], srichards and 197 guests
