Hesitation
saulcupra
Re: Hesitation
Post by saulcupra » Thu Jul 03, 2014 1:49 pm
RS6 has 2 pumps no?
Re: Hesitation
Post by bam_bam » Thu Jul 03, 2014 2:08 pm
saulcupra wrote:RS6 has 2 pumps no?
Yes. Getting them to work together above a certain threshold is nose-bleed stuff, apparently. At leaset it was with Darth, I wonder what the 778HP manual uses... I really should get to know it better.
rossi46
Re: Hesitation
Post by rossi46 » Thu Jul 03, 2014 2:14 pm
So if moving away from the OE fuel pumps it would be the case that 2x 044's are needed , or does one 'run' the other ?
Hence also asking about tweaking a map and if more fuel being supplied (or at a greater pressure) would deem the original map void ..
Getting on for 800hp must indeed be a headache !!
SuprSi
Re: Hesitation
Post by SuprSi » Thu Jul 03, 2014 2:21 pm
1x 044 would do the job up to 650hp. Before the fuel gets to the injector rails it goes through a regulator that keeps it at the correct pressure (relative to boost pressure) so the tune/mapping of the car is unaffected. So as long as the pump can supply the volume of fuel the engine wants without dropping below say, 5 bar, it's all good.
I wander if you'd get an fault code come up if you changed the two pumps for one.
saulcupra
Re: Hesitation
Post by saulcupra » Thu Jul 03, 2014 2:44 pm
I think one is a lift pump and one is the feed pump if you will
Re: Hesitation
Post by Shoppinit » Fri Jul 04, 2014 1:30 pm
^That.
Nobby
Re: Hesitation
Post by Nobby » Fri Jul 04, 2014 2:00 pm
Both pumps are also controlled to switch between 10v and 12v (depending on engine conditions), but fuel pressure is kept constant by the pressure regulator on the fuel rails.
There's a bit more about how they work in the study guide in Footers directory.
Daytona RS6 Avant
SuprSi
Re: Hesitation
Post by SuprSi » Fri Jul 04, 2014 2:04 pm
That self study guide is really good!
rossi46
Re: Hesitation
Post by rossi46 » Fri Jul 04, 2014 3:15 pm
Great info guys
mavada
Re: Hesitation
Post by mavada » Fri Jul 04, 2014 4:14 pm
So i went to the Audi stealer nearby to get the fuelfilter...
Good morning sir, i need a fuelfilter for my 2003 Audi RS6
''Good morning, i need a license plate or chassisnumber''
Well, its a 2003 RS6 non plus version.
''I need a licenseplate or chassisnumber cos there are loads of types and versions of it''
It is for my RS6 from 2003 non plus, only one version available. partnumber starts with 6N and ends with 511A from memory.
''I still need ...i will have a look...''(in system...slightly bored and annoyed...)
Its a V8 twin turbo.
''Is it diesel or petrol version'' :shock:
No its bi fuel (now im bored to...)
Its the one with the solar roof for the optional hybrid functions...and air suspension...
''I see only one version, petrol''
Ended conversation, will be delivered next Monday...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
SuprSi
Re: Hesitation
Post by SuprSi » Fri Jul 04, 2014 4:27 pm
So much effort on his part! Where do they find these scrotes?
rossi46
Re: Hesitation
Post by rossi46 » Fri Jul 04, 2014 4:34 pm
is it petrol or deisel?? I have had that q too ..
I try to avoid dealers at all costs. Wouldn't mind, but when being charged what, c£150/hr for professional service, there really is no excuse
amanda1
Re: Hesitation
Post by amanda1 » Fri Jul 04, 2014 4:40 pm
rossi46 wrote:is it petrol or deisel?? I have had that q too ..
Mine would never dare not ask that question as they already know what she is :bigblink:
950 nm torque!
Nobby
Re: Hesitation
Post by Nobby » Fri Jul 04, 2014 5:04 pm
I went to a dealer a while back and the parts advisor greeted me with 'What can I do for you sonny?'
Highly professional :roll:
Daytona RS6 Avant
rossi46
Re: Hesitation
Post by rossi46 » Fri Jul 04, 2014 5:17 pm
Sonny ! ?? :audibash:
Nice ..
Users browsing this forum: Google [Bot], srichards and 84 guests
