Rear discs.
Rear discs.
Does anyone know if there are alternatives to the std drilled discs.
I've gone down the Phaeton front disk route and I'm happy with them. I have noticed that you can get a 335mm rear disc for a Phaeton and was wondering if anyone know if the offset of the disc is the same as RS4 rears, then all I'd need to do is space out the rear calipers 10mm.
Any help or answers much appreciated.
Mike
Mike
Re: Rear discs.
TarOx? http://www.tarox.co.uk/product/rear-tar ... 7-bespoke/fireheed wrote:Does anyone know if there are alternatives to the std drilled discs.
Mike
Re: Rear discs.
Spied them but they are a hell of a price.
Re: Rear discs.
What's wrong with the standard discs?
- John Johnson
- 5th Gear
Re: Rear discs.
Nowt wrong with being prudent luvvie
Current toys in the garage
B7 avant in Daytona with ceramics and a few other goodies and lowwwww miles
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
Rs1600i
rwilsonrs4
Re: Rear discs.
the Tarox are more expensive but if the picture is correct they are floating(OEM rears are not ) and higher quality materials so woth the money i say
1/4 mile 12.01 secs 123.5mph
Re: Rear discs.
you bought an RS . nothing cheap here, could always do a A4 rear swap and have solid rear disks for about £80 quid
Re: Rear discs.
They are going to cost what they cost, I've no hassle with that. I just fancied non drilled/grooved discs to match the front. If not ill probably go down the standard disc route.
WilkinsonRS4
Re: Rear discs.
Is Tarox a good quality comparable disc to use?rwilsonrs4 wrote:the Tarox are more expensive but if the picture is correct they are floating(OEM rears are not ) and higher quality materials so woth the money i say
I was thinking of them with Yellow Stuff pads set up on the front as my discs are needing doing soon.
Front Tarox discs are £660.00 a pair, Fitting cost £50 and EBC yellowstuff pads are £189.00 for the set.
That's my quoted cost!!
Modified standard exhaust Modified deflapped inlet manifold ported and polished
Head and valve decoke Performance K&N panel filter. Remapped. Lowered slightly (20mm) on KW performance springs Widened on 10mm spacers.
- flying_tomatoes
Re: Rear discs.
Stoptech makes a nice set of two piece rear rotors that can be had in drilled, slotted or plain.
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 235 guests
