Rear discs.
fireheed
Rear discs.
Post by fireheed » Fri May 30, 2014 11:06 pm
Does anyone know if there are alternatives to the std drilled discs.
I've gone down the Phaeton front disk route and I'm happy with them. I have noticed that you can get a 335mm rear disc for a Phaeton and was wondering if anyone know if the offset of the disc is the same as RS4 rears, then all I'd need to do is space out the rear calipers 10mm.
Any help or answers much appreciated.
Mike
sync24
Re: Rear discs.
Post by sync24 » Sun Jun 01, 2014 12:46 am
fireheed wrote:Does anyone know if there are alternatives to the std drilled discs.
Mike
TarOx? http://www.tarox.co.uk/product/rear-tar ... 7-bespoke/
fireheed
Re: Rear discs.
Post by fireheed » Tue Jun 03, 2014 3:57 am
Spied them but they are a hell of a price.
Re: Rear discs.
Post by MikeFish » Tue Jun 03, 2014 6:55 am
What's wrong with the standard discs?
coffey555
Re: Rear discs.
Post by coffey555 » Tue Jun 03, 2014 7:14 am
Going by the first post, price?
Misano Red RS4 B7 Avant
John Johnson
Re: Rear discs.
Post by John Johnson » Tue Jun 03, 2014 6:15 pm
Nowt wrong with being prudent luvvie
Current toys in the garage
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
rwilsonrs4
Re: Rear discs.
Post by rwilsonrs4 » Tue Jun 03, 2014 9:09 pm
the Tarox are more expensive but if the picture is correct they are floating(OEM rears are not ) and higher quality materials so woth the money i say
1/4 mile 12.01 secs 123.5mph
Rick_RS4
Re: Rear discs.
Post by Rick_RS4 » Tue Jun 03, 2014 9:56 pm
you bought an RS . nothing cheap here, could always do a A4 rear swap and have solid rear disks for about £80 quid
fireheed
Re: Rear discs.
Post by fireheed » Wed Jun 04, 2014 1:20 am
They are going to cost what they cost, I've no hassle with that. I just fancied non drilled/grooved discs to match the front. If not ill probably go down the standard disc route.
WilkinsonRS4
Re: Rear discs.
Post by WilkinsonRS4 » Tue Jun 10, 2014 4:25 pm
rwilsonrs4 wrote:the Tarox are more expensive but if the picture is correct they are floating(OEM rears are not ) and higher quality materials so woth the money i say
Is Tarox a good quality comparable disc to use?
I was thinking of them with Yellow Stuff pads set up on the front as my discs are needing doing soon.
Front Tarox discs are £660.00 a pair, Fitting cost £50 and EBC yellowstuff pads are £189.00 for the set.
That's my quoted cost!!
Modified standard exhaust Modified deflapped inlet manifold ported and polished
Head and valve decoke Performance K&N panel filter. Remapped. Lowered slightly (20mm) on KW performance springs Widened on 10mm spacers.
flying_tomatoes
Re: Rear discs.
Post by flying_tomatoes » Thu Jun 12, 2014 2:02 pm
Stoptech makes a nice set of two piece rear rotors that can be had in drilled, slotted or plain.
2007 RS4 - Bagged and Blown. IG: @Flying_Tomatoes
Users browsing this forum: Google Adsense [Bot] and 213 guests
