Thanks in advance
Phone quiet when connected to Bluetooth
Littlerick
My I phone 5 is connected to my stereo via Bluetooth and whenever I receive or make a call it is quiet I can turn phone down using the volume button but it will only go up to a certain volume does anyone else have this problem or know what I can do to prevent this
Thanks in advance
Thanks in advance
Re: Phone quiet when connected to Bluetooth
I have he opposite - deafens me every time I get a call!
- NJMAudiRS4
Not overly sure it can be done, but if you press the TEL ( telephone) button on your system then press the setup button does it give you the option to alter any settings ? Worth a go
Audi RS4 Avant. MRC Stage 2 Manifold, caf, Map, JCWF Manifold back Exhaust with Sports Cats, H&R spacers, 449ps & 483nm
I though the volume level could be adapted/coded via VCDS - just looked on the wiki and it can't
Mine seems OK, so leads me to believe it is controllable...
Gone but never forgotten:
Just adjust the volume when you're on a call and the rns-e will save it at that level
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
Littlerick
C17LJR wrote:Just adjust the volume when you're on a call and the rns-e will save it at that level
Still not that loud though
PetrolDave will be along soon. The oracle of all things electrical will speak!
- PetrolDave
The volume in a call is set by two things - the volume setting on your phone AND the volume setting on the RNS-E.
So if you have you phone volume set really low then turning the RNS-E volume up to max won't help much.
Littlerick
Both set up fullPetrolDave wrote:The volume in a call is set by two things - the volume setting on your phone AND the volume setting on the RNS-E.
- PetrolDave
Then AFAIK that's as loud as it can get.Littlerick wrote:Both set up fullPetrolDave wrote:The volume in a call is set by two things - the volume setting on your phone AND the volume setting on the RNS-E.
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 176 guests
