Phone quiet when connected to Bluetooth
Littlerick
Post by Littlerick » Thu May 01, 2014 12:33 am
My I phone 5 is connected to my stereo via Bluetooth and whenever I receive or make a call it is quiet I can turn phone down using the volume button but it will only go up to a certain volume does anyone else have this problem or know what I can do to prevent this :?
Thanks in advance
adsgreen
Re: Phone quiet when connected to Bluetooth
Post by adsgreen » Thu May 01, 2014 12:54 am
I have he opposite - deafens me every time I get a call!
NJMAudiRS4
Post by NJMAudiRS4 » Thu May 01, 2014 8:01 am
Not overly sure it can be done, but if you press the TEL ( telephone) button on your system then press the setup button does it give you the option to alter any settings ? Worth a go
neilparf
Post by neilparf » Thu May 01, 2014 11:23 am
I though the volume level could be adapted/coded via VCDS - just looked on the wiki and it can't :(
Mine seems OK, so leads me to believe it is controllable...
Gone but never forgotten:
C17LJR
Post by C17LJR » Thu May 01, 2014 7:37 pm
Just adjust the volume when you're on a call and the rns-e will save it at that level
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
Littlerick
Post by Littlerick » Fri May 02, 2014 9:07 am
C17LJR wrote:Just adjust the volume when you're on a call and the rns-e will save it at that level
Still not that loud though
sync24
Post by sync24 » Fri May 02, 2014 9:30 am
PetrolDave will be along soon. The oracle of all things electrical will speak!
PetrolDave
Post by PetrolDave » Fri May 02, 2014 2:48 pm
The volume in a call is set by two things - the volume setting on your phone AND the volume setting on the RNS-E.
So if you have you phone volume set really low then turning the RNS-E volume up to max won't help much.
Littlerick
Post by Littlerick » Sat May 03, 2014 1:03 pm
PetrolDave wrote:The volume in a call is set by two things - the volume setting on your phone AND the volume setting on the RNS-E.
Both set up full
PetrolDave
Post by PetrolDave » Sat May 03, 2014 1:59 pm
Both set up full
Then AFAIK that's as loud as it can get.
Users browsing this forum: Majestic-12 [Bot] and 398 guests
