Sounding off.....
coffeechris
Sounding off.....
Post by coffeechris » Thu Apr 24, 2014 9:53 am
Hi, I'm a new RS+ owner and loving it (2004).
I don't suppose anyone knows where the fuse for the Bose Amp is? I had lovely sound and now lost it - everything works, but no sound.... no mute symbol etc.. thought best to check Amp.
Many thanks
Re: Sounding off.....
Post by Shoppinit » Thu Apr 24, 2014 10:24 am
It's the same fuse for the amp as for the RNS-D, so if your RNS-D is working, it's not the fuse.
Either there's a problem with the amplifier itself or it's not getting anything from the head unit.
You could try poking around in the engineering menu of the RNS-D to see if there are any leads in there.
coffeechris
Post by coffeechris » Thu Apr 24, 2014 6:49 pm
Hmmm, I seem to have an RNS-E if that makes any difference?
Shoppinit wrote:It's the same fuse for the amp as for the RNS-D, so if your RNS-D is working, it's not the fuse.
Post by Shoppinit » Thu Apr 24, 2014 6:51 pm
Now he tells us... :roll: :wink:
Post by Shoppinit » Thu Apr 24, 2014 6:57 pm
It's the same deal, I'm afraid. The wiring is exactly the same for the D/E to the Bose amp. Wouldn't hurt to check that you're getting power to the amp, though. It's the red/yellow wire. Check the earth, too. It could be that simple.
coffeechris
Post by coffeechris » Thu Apr 24, 2014 9:31 pm
Ok - Is that ground throughout the system or just at Amp? Where is the Bluetooth module hidden away as I know that was updated too....
will take a gander over the weekend.
Shoppinit wrote:It's the same deal, I'm afraid. The wiring is exactly the same for the D/E to the Bose amp. Wouldn't hurt to check that you're getting power to the amp, though. It's the red/yellow wire. Check the earth, too. It could be that simple.
Users browsing this forum: Bing [Bot] and 111 guests
