Thanks in advance!
Shortened number plate holder
I have a 6-digit plate I'm planning to put on the rs4 when it arrives and like a short plate to minimise the amount of unoccupied white space. Has anyone shortened the front plate holder or is a shortened plate holder available from anywhere?
Thanks in advance!
Thanks in advance!
Re: Shortened number plate holder
You'll be able to buy a us or jap spec plate holder from audi or tps, alternatively you could cut a section out of a standard holder and plastic weld it back together then refinish it
2007 Daytona Grey RS 4 Avant
2013 Daytona Grey RS 4 Avant
Smart thinking. Will need to find a plastic welding expert.
Speak to your dealers parts department, there are a couple of sizes available for the plate holder. I know as I've asked the very same question.cmcm3 wrote:I have a 6-digit plate I'm planning to put on the rs4 when it arrives and like a short plate to minimise the amount of unoccupied white space. Has anyone shortened the front plate holder or is a shortened plate holder available from anywhere?
Thanks in advance!
It's all torque talk.
C17LJR wrote:You'll be able to buy a us or jap spec plate holder from audi or tps, alternatively you could cut a section out of a standard holder and plastic weld it back together then refinish it
That is what I did...cut out middle section etc..
Worked a treat.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
carsarecool
Any pics?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Only thing I would off done different is screw the plate holder on then stuck the number plate on with double sided tape I just don't like the screw caps
Astonished
I've got short plates too, that I will be transferring across when the new RS4 arrives, so will look at same options.RS6chris! wrote:....
This looks like a good solution.
Does anyone have any pics of the rear of the plate holder and the grille and the fixings between the two?
Thanks heaps
