Windscreen Wipers Stopped
Driving out of London yesterday and my wipers stopped working. I've tried moving the switch through all it's positions quickly just in case it was a dirty switch and it hasn't helped. The obvious thing to do is check the motor....
Has anyone had a similair problem and has any hints or tips ?:)
TarmacTerrorist
- 5th Gear
RE: Windscreen Wipers Stopped
Checked the fuse and that is working. That particular fuse runs the washers, wipers and intermittent wipers.....the washers still work so....looks like the motor....
- gavsteryoung
When I was looking through the history on my car the other day, I noticed that the car went into Audi.
The problem description read that the Wipers just would not work one morning.
They found the mechanism had seized so it had new mechanism under warrenty. Does not say it had a new motor!
Guess this is all it can point to! Motor or Mechanism
regards
Gav
regards
Gav
I've got most of it apart but I'm struggling to get the whole unit (motor and mechanism) out. It looks like I'll have to take out the ECU and the ECU box before it will move. Problem is if I do that the car is stuck where it is until the ECU is refitted.....therefore I can't go for parts.
Local stealer has a open slot in their workshop next Tuesday......!
Waiting to hear from the parts department if they have the mechanism as well as the motor.
Since the whole thing stopped suddendly I'm thinking motor but I don't want to take the rest of the bits off the car and find it's the mechanism....Ohh and the heating in the house has packed up as well.....
2005 is not such a good year so far then...
2001 Silver S4 Avant
- gavsteryoung
Jeff,
your not alone, my boiler at home now has a waterpump leak just like my car did last year.....
Cant get new parts for 10days so had to resort to a big bucket..... at least my heating is still working!
Yeah, my boileer went a couple of months ago, just when it turned f***ing freezing and it took the plumber a week to come and diagnose, then another week to get the parts and fix - 2 of the coldest weeks of my life - never good when you can see your breath while sitting wathcing TV!!!
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten
Have you tried to to check that power is getting to the motor with a simple power tester plus does it use a relay as I'm sure it dose for the delay part of it.
If all fails I have a RS4 shell that has all the parts you need.
QuantumJohn
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 128 guests
