Nokia CARK-91 Hands Free Kit
Does anyone know if you can get a cable that mutes the stereo and then you can speak through the standard car stereo speakers, rather than the little nokia speaker.
I have been told that it is not possible with the bose stereo system, by the guy that installs my car kit! but find this strange as it will be the first car I have owned where this is not possible
I have a 99 S4 Avant with the Concert Stereo, Bose Upgrade & Sat Nav
Re: Nokia CARK-91 Hands Free Kit
have you got the full sat nav plus, if so yep it is possibel
Need to speak to NickM
Can't beat a bit of boost!
No, no such luck just the standard sat nav with the in dash display [img]images/graemlins/crazy.gif[/img]
I had the Bose system and the hands free kit was installed with the mute function. It was also retained when I upgraded to Sat Nav.
Apparently.....
Talking to the guy putting in my wifes new CD Autochanger yesterday you can mute from the Nokia but you can't use the speakers because of the amplifiers in the Bose set-up.
how do audi do it then
it is an option on their car kits?
Maybe they wire the phone into the amps on build....don't know really, just guessing.
The mute works fine, and cuts the stereo and you get a german message on the stereo and in the dash that prob says "Phone" but you cannot use the stereo speakers so I have to put up with the silly little speaker that nokia supply
Hi Mate,
Dunno how good you are with a crimper/soldering iron, but trust me anything is posssible.
I'd be temped to get myself a couple of changeover relays and wire them in so that the same signal that you use to mute your system also operates the relays which could be used to break the signal running to the front speakers from the amp and reroute the output from your incar kit.
If you are paranoid about running an amp with no load on it (which personally I would be) then get some wirewound resistors too of about 4-8ohm and wire the system so that when the speakers are disconnected from the amp the resistors are wired across it instead.
Depends on how much troble you want to go to really.
If interested post back and I'll upload some schematics or something (could probably even build it for you if you wanted, but you'd be looking at about £50-100 I would imagine)
-Dan
Users browsing this forum: No registered users and 39 guests
