Rolling Road Day at QST
VST
Post by VST » Fri Dec 03, 2004 7:05 pm
The other side of it is my old S3 spent a day(!) on the rollers with the fuse pulled when Peter Link mapped the car,with no adverse affects.....this is the procedure MTM use themselves in Germany,its not something Kim came up with himself and decieded to give it a go.
I'd find it hard to believe that a German tuner operating under the strict TUV guidelines and procedures that they have,would advocate such a procedure if there was any element of risk involved,they are an ultra cautious,conservative shower after all. :D
MTM RS4
UK225
Post by UK225 » Sat Dec 04, 2004 7:11 pm
Hi guys,
I am not interested in running with the fuse for the haldex pulled either.
If Kim changes his mind then I would still like to run.
Morgan
Nordschleife
Post by Nordschleife » Sun Dec 05, 2004 6:43 pm
There is a world of difference between MkI and MkII Haldex. Mk I is open loop and completely unpredictable - ie you can drive the same corner in exactly the same way and get two entirely different results. With a Haldex controller ther is much less to worry about when it comes to putting cars on dynos.
R+C
VST
Post by VST » Sun Dec 05, 2004 7:03 pm
My car had an MTM haldex controller fitted,Peter still chose to remove the fuse,I discussed this with him at the time......
MTM RS4
clived
Post by clived » Sun Dec 05, 2004 9:05 pm
Nordschleife wrote:There is a world of difference between MkI and MkII Haldex. Mk I is open loop and completely unpredictable - ie you can drive the same corner in exactly the same way and get two entirely different results. With a Haldex controller ther is much less to worry about when it comes to putting cars on dynos.
R+C
I didn't know there was a MkI and a MkII.....? Unless you mean (as the rest of your post sort of suggests) that fitting the aftermarket controller makes it a MkII?
Clive
Prawn
Post by Prawn » Mon Dec 06, 2004 11:04 am
OK spoke to Kim this morning.
He is happy to run Haldex cars in 4WD or 2WD whichever the owner would prefer.
Still on for this Saturday, can you all re-confirm so I can get the final numbers.
Refreshments and Mince pies available from 9AM.
If you have a preferance for a time let me know as well.
Prawn
simonelman
Post by simonelman » Mon Dec 06, 2004 11:17 am
I`m still up for it
I`ve just fitted a Dahlback inlet manifold and should be nice to see some power increase
Simons3MTM
DuncS3
Post by DuncS3 » Mon Dec 06, 2004 11:52 am
Cheers Prawn, in that case count me (back) in!
and no secretly pulling the fuse!
Dunc
sitas3
Post by sitas3 » Mon Dec 06, 2004 11:56 am
i'm in. see you there.
a morning slot for me please. Thanks.
PhilT
RS246.com
Post by PhilT » Mon Dec 06, 2004 12:30 pm
Anybody going to this and the Northern meet on the 20th... I need a favour.
bjacks
Post by bjacks » Mon Dec 06, 2004 12:37 pm
simonelman wrote:I`m still up for it
Simons3MTM
Is that with the standard turbo Simon? :wink:
I'm still in, a.m would be handy also.
Ben
simonelman
Post by simonelman » Mon Dec 06, 2004 12:51 pm
Hi Ben
Hows tricks?
Yes with stnd turbo :bash:
SimonS3MTM
bjacks
Post by bjacks » Mon Dec 06, 2004 12:57 pm
Perfect opportunity to upgrade though :D
What increase we looking at?
Yep, things manic but good. I need to speak to you about something so will give you a bell.
Ben
ChrisG
Post by ChrisG » Mon Dec 06, 2004 1:36 pm
Yep I'm still in, earlier the better please - 9am - 10 am would be good please ??
This would be a good chance for JR to get some base figures - :) shame it's a Saturday :(
ChrisG
simonelman
Post by simonelman » Mon Dec 06, 2004 2:27 pm
Dahlback say 30bhp on a 300bhp 1.8t motor :roll:
So I recon 10-15 at most Which should push it over the 300 mark.
The problem I find is that as I increase the boost nearer to 2bar the torque goes up 340lbs but the power goes down.
SimonS3MTM
