Exhaust options: more "growl" but not too loud?
maars
Re: Exhaust options: more "growl" but not too loud?
Post by maars » Sun Oct 06, 2013 11:53 am
Who makes the best x pipe? Can it be fitted without a remap?
Daytona RS4 Avant - black optics/decat downpipes/H-pipe/KW springs - featured on the 2012 Audi stand at the Goodwood FoS
maars
Post by maars » Sun Oct 06, 2013 2:41 pm
brian5362 wrote:http://youtu.be/EVM6z4iCMHU
This said it is standard exhaust with a x-pipe replacing the resonator section sound nice IMO
That sounds superb!
Post by MikeFish » Sun Oct 06, 2013 7:58 pm
The standard exhaust already has a x-pipe.
Post by MikeFish » Sun Oct 06, 2013 7:59 pm
m14rrv wrote:i did a search for the x pipe, but not much came up just this tread, what gains do you get? or is it more of sound thing?
Did you search for 'scavenging' as I suggested? Loads of posts come up when I searched.
rocket1
Post by rocket1 » Sun Oct 06, 2013 8:06 pm
that video clip sounds great and a big difference in valve open/closed. so thats a standard system with centre box removed and x pipe fitted? anyone recommend anywhere in southwest uk that could supply and fit the section??
repsol honda fireblade.
maars
Post by maars » Sun Oct 06, 2013 9:15 pm
MikeFish wrote:The standard exhaust already has a x-pipe.
OK, so what does the x pipe mod change then?
Post by MikeFish » Sun Oct 06, 2013 10:14 pm
On the OEM exhaust the x pipe is also the centre resonator. So if you want to remove this centre resonator for a better noise you have 2 options; just replace it with the straight through pipes, or replace it with another x pipe but without the resonator killing the sound. Clearly the second option is best as without the x pipe you lose the scavenging effect that the standard exhaust has, but, and I am no expert, you could probably recover some of the loses of a system with no x pipe by remapping.
maars
Post by maars » Sun Oct 06, 2013 10:30 pm
MikeFish wrote:On the OEM exhaust the x pipe is also the centre resonator. So if you want to remove this centre resonator for a better noise you have 2 options; just replace it with the straight through pipes, or replace it with another x pipe but without the resonator killing the sound. Clearly the second option is best as without the x pipe you lose the scavenging effect that the standard exhaust has, but, and I am no expert, you could probably recover some of the loses of a system with no x pipe by remapping.
I see. And the resonators are there to keep the noise levels down to meet a manufacturing spec?
No issues with the MOT with the x pipe replacement then?
Post by MikeFish » Sun Oct 06, 2013 11:20 pm
Yes, correct.
No issues with MOT, it does nothing for emissions. I have no precats and no centre resonator and have no problems with MOTs.
maars
Post by maars » Sun Oct 06, 2013 11:27 pm
Sounds like a great, and simple mod then. Thanks Mike.
So who makes a good off the shelf x pipe for a stock system?
Post by MikeFish » Mon Oct 07, 2013 12:06 am
Nobody that I know of. The stock exhaust is one piece from the cat back, so any changes mean you need a compete cat back system or need a custom made exhaust. You could try and go in the middle and get something like a Milltek h pipe (same as an x pipe) and their centre section, then get a fabricator to cut the OEM exhaust and mate the 2 bits together. The Milltek H pipe will fit straight onto the standard cats.
Post by MikeFish » Mon Oct 07, 2013 12:16 am
Custom exhaust will probably be cheaper and better quality though, although this will very much depend on who you go to.
TonyHayers
Post by TonyHayers » Mon Oct 07, 2013 10:24 am
I'm not sure that the stock centre resonators join in the housing - doesn't seem wide enough in the middle.
06 Phantom Black Saloon:
^ GONE :cry:
Post by MikeFish » Mon Oct 07, 2013 1:25 pm
The centre resonator is wider than the 2 pipes that go into it. And why would they go into one box when every other component in the exhaust system has an individual left and right part? It's the only part of the whole exhaust that is joined.
nij
Post by nij » Tue Oct 08, 2013 9:23 am
+1
MikeFish wrote:The centre resonator is wider than the 2 pipes that go into it. And why would they go into one box when every other component in the exhaust system has an individual left and right part? It's the only part of the whole exhaust that is joined.
It's flat in the middle between the two pipes. Probably cheaper to make one part than to make two and to give it rigidity.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
Users browsing this forum: Google [Bot] and 263 guests
