Transplanting a RS4 engine into a S4
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
kozmos
Post by kozmos » Mon Nov 22, 2004 3:42 pm
Transplanting newer engines into older Porsche 911 is very common amongst Porsche owners but has anyone installed a RS4 engine into their S4?
If so, where can I buy a new RS4 engine and all the necessary fittings?
Some of you may think I'm totally nuts, but where I live, RS4s are NOT available. Modding the S4 is not the preferred route, because there's insufficient local knowledge on mods (unless I drive a EVO or WRX).
DuncS3
Post by DuncS3 » Mon Nov 22, 2004 5:01 pm
Dont know about a new engine but do a search on the site as it has been done with an engine from a broken RS4 (actually the car was for sale but not sure now)
Dunc
Morpheous
Post by Morpheous » Mon Nov 22, 2004 8:58 pm
Better off buying a written off RS4 with rear end damage cos there are LOTS of different bits you will need, not to mention the dash insert as engine ecu needs to see a valid immobiliser serial number.
S4RS4
Re: Transplanting a RS4 engine into a S4
Post by S4RS4 » Mon Nov 22, 2004 9:36 pm
[quote="kozmos"]Transplanting newer engines into older Porsche 911 is very common amongst Porsche owners but has anyone installed a RS4 engine into their S4?
Yes, I did. It is quite straight forward really. The only problem I had was i started off with an early pre-facelift S4 which meant I could not use an RS4 ECU. If you start with a late model S4 you will be fine. The only parts to change other than the engine are the intercoolers. Also, I would add the oil cooler cos the S4 does not have one.
Your problem will be finding an engine! I did this conversion because an RS4 engine came up for sale - not the other way around! I sold the S4 engine so the cost was relatively OK.
Morpheous
Post by Morpheous » Tue Nov 23, 2004 12:16 am
How much did your insurance go up by? Do they class it as an RS4 or does it come under Modified?
kozmos
Post by kozmos » Tue Nov 23, 2004 8:55 am
S4RS4 wrote:
kozmos wrote:Transplanting newer engines into older Porsche 911 is very common amongst Porsche owners but has anyone installed a RS4 engine into their S4?
Hmmmm, very interesting, perhaps you can elaborate on your modification. What parts were required and how long did the transplant take?
Surely you can buy a reconditioned RS4 engine from the factory? I own a Porsche 993 and buying reconditioned Porsche engines from Porshce AG is not uncommon and they're as good as new. A friend of mine swapped his 964 engine for a factory (warranted) recondition engine 2 years ago and paid equiv 10k pounds. The reconditioned engine came in a pallet direct from the factory and was essentially a brand new unit. Run-in procedure is the same as a brand new car.
S4RS4
Post by S4RS4 » Tue Nov 23, 2004 8:52 pm
Morpheous wrote:How much did your insurance go up by? Do they class it as an RS4 or does it come under Modified?
Classed as modified and they stung me another £200 or so.
S4RS4
Post by S4RS4 » Tue Nov 23, 2004 8:55 pm
Like I said above, the only parts different to my knowledge are the intercoolers and the addition to the S4 is the oil cooler. Just remembered the fuel pump is different too although some folks run high power S4's on the S4 pump. Just bolt it in and plug in the RS4 ECU.
Nordschleife
Post by Nordschleife » Tue Nov 23, 2004 9:40 pm
a little knowledge, then........
S4RS4
Post by S4RS4 » Tue Nov 23, 2004 10:33 pm
Alright clever arse, I was referring to the fitment of the RS4 engine to the S4, not the differences in the two engines. You know better?
Diesel
Post by Diesel » Wed Nov 24, 2004 9:58 am
Should be able to do the job on a dry Saturday morning no probs :wink: You'll need to change your underpants mind :lol:
My insurance quotes were the same for an S4 and an RS4 (both with ECU & exhaust mods)... Wasnt insured in Singapore la mind...!
Users browsing this forum: Majestic-12 [Bot] and 127 guests
