lengster1 wrote:Hmm anyone edit my reg out for me?
Better?
Well i'm glad to say that it was worth the wait. Looks really good. can see why the delay in update.
Alex
Firestarter wrote: A few things to ask.
1, The spare key wasn't working so replaced the battery. It starts the car but the remote functions don't work....Any ideas as to what this issue could be?
2, Can the rear windows be mad to open fully as they both only open approx 3/4
Im sure there will be more but for now I must start work!!
Timster wrote: Really think you’ve made a booboo with the gloss black on the disks though….. and have you painted the mating-surfaces ??![]()
(you’ll vibrate/wobble like fcuk)
Oops.....Well only done the front o/s so will hold off doing the rest. Drove the car last night and the brakes felt fine even under some heavy braking and no wobble. Same today and again had several "high speed" sorties together with lots of heavy braking......again no wobbles and brakes feel very goodTimster wrote:Good effort with all the work you’ve done so far.
Thanks Mike,MikeFish wrote:Louie
C17LJR was right that that windows won't go down fully because of the cut away section of the door for the rear wheel arch, it just won't physically fit! The only way to make it fully lower would have been to plit the glass into 2 sections.
Normally, the back window will only fully open if the glass has been divided into 2, with a movable rectangular section at the front and a fixed non-movable section behind it. This smaller glass therefore has enough room to fully lower.
Take a look at a side view of a Nissan Navara (for no other reason than I own one and know off-hand that the glass is like this) and you can see the 2 window sections and why they fully open, then look at your RS and you can see that the size and shape of the glass just can't fully lower into the door.
CheeRS Sam,Surrey Sam wrote:Firestarter wrote: A few things to ask.
Louie,
With regards to the key remote, have a read through the user manual - I know that's an alien thing to us blokesbut there should be a process described to soft re-set the remote fob to the car. If this doesn't work then it will need a more involved process with VCDS software and a lead.
Link to the second process is - Ross-Tech remote control matching
and video
Users browsing this forum: Majestic-12 [Bot] and 149 guests
