Thats what I am thinking. If it is and you have the same you will be in no doubt if their the same as minemoondog wrote:Bad batch of tyres? Hope not, as ive just put 4 of the same on mine. I'll be interested to see if it is the Goodys.
Dodgy Rear End issue.....
- esp_mm-270
Re: Dodgy Rear End issue.....
- esp_mm-270
Mines on a ship in the Med heading to nz at present. I had th Goodys on a week b4 shipping and didnt notice any problems, which included a good thrashing around some b roads out of town. When I get it out of the container in 5 or 6 weeks, I'll have a good look at it.
I assume theres a batch number printed on the tyre somewhere, which might narrow things down if there are other drivers with same prob.
Best of luck with it.
Daytona B7 RS4 Avant soon to be terrorizing NZ roads.
- esp_mm-270
Batch number huh....? Hmmm, I'll be checking for that and am sure mine are an isolated manufacturing error (assuming that is the issue)moondog wrote:Mines on a ship in the Med heading to nz at present. I had th Goodys on a week b4 shipping and didnt notice any problems, which included a good thrashing around some b roads out of town. When I get it out of the container in 5 or 6 weeks, I'll have a good look at it.
Every tyre has the year and week (or is it month?) of production on it.
Mark - mine moves like yours in the video - it's not excessive by any means though - I run the same tyres as you but I run KW's as well - I would be very surprised if it's the tyres mate.
I've never ever seen anything quite like that.esp_mm-270 wrote:Just done a small vid so you can see what I mean. My back is screwed so I can't put excessive lateral load through it but the tyre moves right up the sides
http://www.youtube.com/watch?v=dVTBSPhU ... e=youtu.be
I know sounds silly but it is the right size?
Why not try contacting Goodyear am sure they will be all over this if think may have supplied dodgy tyres ?
255/35-19 can't remember the make, they re some ditch finders that came on the car.esp_mm-270 wrote:Thanks so much for checkingbrn7y wrote:I did this also and mine does not move at all.Do you have 255/35/19's? Which make? Thanks in advance.
But unlike yours I cannot even push the car like you did, car or tyre will not move.
Audi Pardner
Just tried the wobble test on mine and there was barely any movement, it certainly wasn't like yours! It must be the tyres surely?
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
The only way forward is like Coffey said swap fronts to back, and go for a drive to compare
- esp_mm-270
Sorry for late response but thanks for all the input and I'll be checking and ringing around tomorrow.
Again, thanks for all the ideas and feedback all of which I can use/help to resolve the issue
I'll post up outcome as soon as I can.
- esp_mm-270
Yeah they are but I know what you mean loladsgreen wrote:I've never ever seen anything quite like that.esp_mm-270 wrote:Just done a small vid so you can see what I mean. My back is screwed so I can't put excessive lateral load through it but the tyre moves right up the sides
I'd definitely get your suspension looked at.
Anyone checked the ARB?
Arb a possibility but that tyre movement isn't right. I wonder if a couple steel threads have broken on the sidewall.
Just a double check - the tyres are 255/35r19 XL 's ?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 255 guests
