Re-mapping ? Where to go
Hi there
Can anyone recommend a place for remapping my s4 in the midlands
- BlingBling
Re: Re-mapping ? Where to go
What other mods have you done? To get the most out of a map some changes to the exhaust system is recommended.
MRC
MRC
MRC Tuning Banbury, Oxfordshire
Even with a zort upgrade you will only get around 20bhp extra i think. Alot of money for very little back, thats why i didn't have mine done (plus i'm a tight arse)
FON and as bam says, RULE 1!!
Colinurquhart
To get the best from a remap your best to gut the precats first as they are so restrictive, fit an aftermarket exhaust as the standard back boxes are also quite restrictive then get a remap. Hope this helps.
I finally got round to flashing the car today with a JHM 91 octane tune. I have catless DP's and Miltek. It's certainly woken the car up. Will be interesting to see what dyno says..
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
More vids!!!!!ASC wrote:I finally got round to flashing the car today with a JHM 91 octane tune. I have catless DP's and Miltek. It's certainly woken the car up. Will be interesting to see what dyno says..
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
Sounds awesome.
People need to realise you can now flash the jhm tune over the Internet in your driveway. Just order the tune and a cable, and it gets mailed to you. Then log in to their server.
I have a cable and a friend used it to tune his rs4. Took 30 minutes or so.
- Firestarter
MRC are over expensive compared to AmD. I'm here at AmD as just dropped Mr T in for a load of work. MRC were £1000 dearer for the exact same work. Sorry but that's taking the piss. Granted they are good but no way are they 33% better as that's how much dearer they were than AmD
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Firestarter wrote:MRC are over expensive compared to AmD. I'm here at AmD as just dropped Mr T in for a load of work. MRC were £1000 dearer for the exact same work. Sorry but that's taking the piss. Granted they are good but no way are they 33% better as that's how much dearer they were than AmD
Have you used Mrc to be able to come to such conclusion?
Louie, given your recent experiences, have your opinions changed?S4Player wrote:Firestarter wrote:MRC are over expensive compared to AmD. I'm here at AmD as just dropped Mr T in for a load of work. MRC were £1000 dearer for the exact same work. Sorry but that's taking the piss. Granted they are good but no way are they 33% better as that's how much dearer they were than AmD
I had my B7 S4 remapped by MRC, great guys and great service and hopefully I'll be taking my C6 RS6 there soon. IMHO though it's not worth remapping the B6/7 S4 at all. I spent £1000 on an exhaust and roughtly the same from memory on the remap and filters and other than volume it gave no noticable improvement at all. It's just not worth the effort and expense, either spend some real money and supercharge it, buy a faster base Audi or enjoy it as it is. It's not exactly slow in standard form?!
R33 wrote:I had my B7 S4 remapped by MRC, great guys and great service and hopefully I'll be taking my C6 RS6 there soon. IMHO though it's not worth remapping the B6/7 S4 at all. I spent £1000 on an exhaust and roughtly the same from memory on the remap and filters and other than volume it gave no noticable improvement at all. It's just not worth the effort and expense, either spend some real money and supercharge it, buy a faster base Audi or enjoy it as it is. It's not exactly slow in standard form?!
Will a stage 1 re-map not result in better fuel efficient(marginal though I am sure) and smoother power delivery?
