front end fan.
the6
front end fan.
Post by the6 » Mon Jul 08, 2013 3:40 pm
comes on full tilt on start up and continues like it all the time the car is running, when the car is off, the fan will lower in tone slowly and then run for approx 4 mins.
Its sounds like an aeroplane, not noisy but irritating. Can I do anything to stop this? I don't want to map it out (if there is such a fix) bviously fan is there for a reason....But I cant help but think its not normal?
rich
Re: front end fan.
Post by rich » Mon Jul 08, 2013 3:44 pm
I was going to post this. Just wasn't sure if it was supposed to do that. Every single journey it comes on, sounds like its a fighter jet spooling up.
Nobby
Re: front end fan.
Post by Nobby » Mon Jul 08, 2013 3:51 pm
Is your aircon on? If so the fans are in hyper mode.
Daytona RS6 Avant
the6
Re: front end fan.
Post by the6 » Mon Jul 08, 2013 3:52 pm
Aircon fan off.... Its bizarre and bloody noisy..
Re: front end fan.
Post by Shoppinit » Mon Jul 08, 2013 5:03 pm
Either the thermostat, the temp sender or the fan control module is borked. I'm guessing the first. Check your water temps with Vagcom or on the A/C display.
R8GXR
Re: front end fan.
Post by R8GXR » Mon Jul 08, 2013 5:09 pm
Shoppinit wrote:Either the thermostat, the temp sender or the fan control module is borked. I'm guessing the first. Check your water temps with vagcom or on the A/C display.
How do you chek the water temps on the AC display? :boots:
Re: front end fan.
Post by Shoppinit » Mon Jul 08, 2013 5:17 pm
ahoooga
Re: front end fan.
Post by ahoooga » Mon Jul 08, 2013 6:37 pm
Although it was started a long time ago , i think its well worthy of being made a sticky
the6
Re: front end fan.
Post by the6 » Mon Jul 08, 2013 7:33 pm
Thermo!!!??? Noooooooo only bought it as it had thermo done when belts changed recently etc... Faxering fookerfudz..
Anyone got a 'Gina' com any place near me? (Sussex).
ARSE
the6
Re: front end fan.
Post by the6 » Mon Jul 08, 2013 7:37 pm
Water temp on dash always been same, 90..
Re: front end fan.
Post by Shoppinit » Mon Jul 08, 2013 8:02 pm
The dash gauge is fairly meaningless until the temp gets properly out of whack.
Could just be a faulty fan module.
Users browsing this forum: No registered users and 60 guests
