Clunking noise ...
Re: Clunking noise ...
Thought about that to, but forgot how to check that...Is it easier to access now its on a jack?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Not really. Check under the expansion tank to start with. There are 4 bolts total, but my mate's was clunking from there.
But im sure its coming from the right, dont know from where the clunk is coming from a loose steeringrack?
Expansiontank? Sorry dont know where its located...
Yellow Koni's
Yellow Koni's
Where you put the coolant in.
...will have a look...
Yellow Koni's
Yellow Koni's
Cant seem to find 4 bolts...or am i looking in the wrong area?
Yellow Koni's
Yellow Koni's
..any tips to get the new seal in properly? using the flange axle as a guide maybe...?
This is the Elsa-way:
- Attachments
- ac.jpg (55.28 KiB) Viewed 964 times
Yellow Koni's
Yellow Koni's
I normally try and find a socket that's got the right diameter. You won't be able to use the flange, you'll need something that is exactly the same diameter as the oil seal.
...need to find some kind of buttplug then.
Hopefully i get the new one in the right way, depth wise. (the one in the pic is the old one...)
By the way, the diff oil, thats terrible smelling stuff...
Yellow Koni's
Yellow Koni's
An Audi mechanic adviced me to place the seal at a different depth to avoid it touches the flange at the same spot as the old one, but i doubt it will make a difference. Let alone the seal wont hit the part on which it should be pressed against...
Yellow Koni's
Yellow Koni's
Is that a groove in the face?
...i cant feel there is, probably got polished after friction with the seal part. like on the bearingside on the flange, you can see where it touched the bearings side, but cant feel it (green Arrow)...
Yellow Koni's
Yellow Koni's
Was that word dild o?
Hanger 18, area 51
Yellow Koni's
Yellow Koni's
Users browsing this forum: Google [Bot], philS2, Steve2003rs6 and 109 guests
