Clunking noise ...
mavada
Re: Clunking noise ...
Post by mavada » Fri Jul 05, 2013 11:53 am
Thought about that to, but forgot how to check that...Is it easier to access now its on a jack?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Fri Jul 05, 2013 12:03 pm
Not really. Check under the expansion tank to start with. There are 4 bolts total, but my mate's was clunking from there.
mavada
Post by mavada » Fri Jul 05, 2013 12:06 pm
But im sure its coming from the right, dont know from where the clunk is coming from a loose steeringrack?
Expansiontank? Sorry dont know where its located...
Yellow Koni's
Post by Shoppinit » Fri Jul 05, 2013 12:07 pm
Where you put the coolant in.
mavada
Post by mavada » Fri Jul 05, 2013 12:08 pm
...will have a look...
Yellow Koni's
mavada
Post by mavada » Fri Jul 05, 2013 12:25 pm
Cant seem to find 4 bolts...or am i looking in the wrong area?
Yellow Koni's
mavada
Post by mavada » Fri Jul 05, 2013 6:14 pm
..any tips to get the new seal in properly? using the flange axle as a guide maybe...?
This is the Elsa-way:
Yellow Koni's
Post by Shoppinit » Fri Jul 05, 2013 8:11 pm
I normally try and find a socket that's got the right diameter. You won't be able to use the flange, you'll need something that is exactly the same diameter as the oil seal.
mavada
Post by mavada » Fri Jul 05, 2013 8:49 pm
...need to find some kind of buttplug then.
Hopefully i get the new one in the right way, depth wise. (the one in the pic is the old one...)
By the way, the diff oil, thats terrible smelling stuff...
Yellow Koni's
mavada
Post by mavada » Fri Jul 05, 2013 9:15 pm
An Audi mechanic adviced me to place the seal at a different depth to avoid it touches the flange at the same spot as the old one, but i doubt it will make a difference. Let alone the seal wont hit the part on which it should be pressed against...
Yellow Koni's
Post by Shoppinit » Fri Jul 05, 2013 9:18 pm
Is that a groove in the face?
mavada
Post by mavada » Fri Jul 05, 2013 9:21 pm
...i cant feel there is, probably got polished after friction with the seal part. like on the bearingside on the flange, you can see where it touched the bearings side, but cant feel it (green Arrow)...
Yellow Koni's
Post by bam_bam » Sun Jul 07, 2013 8:34 pm
Green <beep> in the background?
Post by Shoppinit » Sun Jul 07, 2013 8:51 pm
Was that word dild o?
mavada
Post by mavada » Sun Jul 07, 2013 8:56 pm
Hanger 18, area 51
Yellow Koni's
Users browsing this forum: Google [Bot] and 71 guests
