Drying towel recommendations?
KernowPete
Anybody got any recommendations for a drying towel, microfibre or otherwise? Been looking at the Chemical Guys Wooly Mammoth which seems to get generally good reviews but any others?? When I've used microfibre in the past they've always left streaks/smears which then need to be buffed out again. I want to avoid that!! Cheers, Pete
Re: Drying towel recommendations?
My mate got a MF towel from Halfrauds and to be honest its quite large and thick and dries really well plus it didn't cost allot.
I have just got a Aqua Gleam 0ppm water filter and I am never going to use my drying towel again (unless I am going to polish the car).
Washed the wife's Phantom Black A3 as the test subject (mine is still clean) WOW, left it to dry naturally and there were no streaks or water marks anywhere, and it honestly looked as shiny as the last time I polished it.
Best £55 I have spent on car cleaning.
+1 for the Aqua Gleam filter - now only towel dry if I need to put the cover on before it has dried naturally! Bloody marvellous
Currently floating along in a 2020 Magnetic Grey Bentley Continental GT & bouncing around in a Navarro S3 black edition
2009 C6 Avant NR Milly, MRC Stage 2/gearbox, MTM 21'' bimotos, H&R arb's, KW coil overs, 756ps & 1085 Nm (now in Simon’s safe hands)
C5 RS6+ No 315 in Metallic Silver (gone but never to be forgotten)
S8 V10 awesome engine but taxi-like gearbox - had to get back to RS motoring
C5 RS6 in Avus Silver - the 1st RS experience
KernowPete
Thanks guys, I've looked at these filters before and also had them recommended by a guy at work. Question though - do they come with standard Hozelock type connectors?
http://www.amazon.co.uk/s/ref=nb_sb_nos ... eam+filter+
looks like there supplied in these links oh and i ordered one so can let you know if i comes with the connectors looks like it does in the photos
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Yep standard hoselock style.
You get 2 connectors with a short piece of hose, you put one connector on either side of the short piece of hose, then connect that to the tap and the inlet end of the filter, you then connect your hose to the outlet end. Job done 2mins.
Works great with the power washer.
Says I should get about 60 washes out of a filter in our soft water area, however with the pressure washer you use half the water so I would hope for more.
Bacardi Jo
Ive been thinking of buying a water filter after reading about them on Detailing World forum ,this is the one that i read good reports about http://www.screwfix.com/p/high-capacity ... _container ,it really needs to be plumbed in so this Aqua Gleam filter seems an easier option ,i use Kent mf drying towels reasonably priced and get good results
Bacardi Jo
Just read the FAQs on the Ultimate Finish website who sell the Aqua Gleam filter Q Can I use the filter in conjunction with a pressure washer?
You can, but it is likely this will use up the filter in one wash. The filter's life is dependent on the amount of water it filters. Therefore forcing a large amount of water through it in one go will deplete it faster than if used connected to a hose pipe. http://www.theultimatefinish.co.uk/foru ... =aquagleam
Think they have got things muddled.
The filter is on the tap side of the pressure washer not the pump side this flows at your standard water pressure.
Bacardi Jo
Your right according to Karcher"s sales literature a pressure washer uses less water than a hosepipe.brn7y wrote:Think they have got things muddled.
I use a leaf blower to dry the car off - any towel or leather will risk scratching the paint!
i used the filter over the weekend and it was great hardly any water left on after the final rince and quick 1 min wipe with a shammy
- Surrey Sam
I currently use an extra large Uber Premium drying towel for the top half and an Elite Gentle Giant one for the bottom half and wheels.
Although I have today just ordered an 8 stage RO water system to feed a storage tank where the jet wash will be fed from. No more drying for me
Was just looking at this, 5 micron is only 900ppm, you would need to fit a 30 micron filter to get 0 ppm. But looks like a good permanent solution if 30 micron filters were available and cheap.blackphantom wrote:Ive been thinking of buying a water filter after reading about them on Detailing World forum ,this is the one that i read good reports about http://www.screwfix.com/p/high-capacity ... _container ,it really needs to be plumbed in so this Aqua Gleam filter seems an easier option ,i use Kent mf drying towels reasonably priced and get good results
Users browsing this forum: No registered users and 111 guests
