I wish there was! But alas not yet! If you download the videos you can hear the engine note - no SC whinePetrolDave wrote:Even 447ps isn't enough to explain a 7.0 time IMHO, that's 550+ps territory - so I'm with sakimano that there's a supercharger lurking in there.MikeFish wrote:Dave, his car is not standard. He has stage 1 manifold, MRC stage 2 remap, Scorpian exhaust, cold air feed and gutted pre-cats. Dyno'd at 447ps.
Terraclean for rs4?
Re: Terraclean for rs4?
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
- PetrolDave
I stick by what I said - 447ps is nowhere near enough to deliver a 7.0 3k-8k time.Gavla wrote:I do remember after the mods Doug saying mine was a quick one and was capable of a fair bit of advanced timing which was probably quicker on the road.
Interesting...will do some more of Arthur's tests to see if I can reproduce those times taken from the iPhone video - might have had a force ten gale behind me who knows...
Even at 447ps that's quick it's supercharged quick
MortenJuul
I did a couple of pulls on the way home
99RON with WMI 15% aprox (375ml 300 PSI methanol) - fuel 9 / timing 5 (438 PS on the dyno)
3.000 RPM - 14:27:18.32 (UTC time)
GPS speed (20hz) - 55.66 Kph
Wheel speed 63.429 kph
8.000 RPM - 14:27:27.18 (UTC time)
GPS speed (20hz) - 150.80
Wheel speed 169.323
Time - 8.86 Sec 3k > 8k
GPS speed increase - 95,14
Wheel Speed increase - 105,894
7.x CANNOT be done (not even downhill in -20C )
Wheel speed 169.323
MortenJuul
[youtube]http://www.youtube.com/watch?v=zhHWssah ... e=youtu.be[/youtube]
2 pulls - 8.86 first pull / 8.95 sec second pull
I have 438PS / 440NM
It is fairly simple math! - I run 8860 millisecons - in order to do 7080 milliseonds, you need 25,14% more power to weight ratio
The car needs to have 3.06503 kg pr PS and therefore 548ps / 550NM to get those kind of numbers (or tires that are 25% smaller i diameter than stock 255/35R19)
PS NM Miliseconds Ratio KG PS / kg
My RS4 438,00 440,00 8.860,00 1.680,00 3,835616438 Power needed
7sec 548,12 550,62 7.080,00 0,80 1.680,00 3,06502984 125,14%
Great sums there however you need to accelerate from 1000rpm to get the momentum past 3krpm, it seems you are starting it at 2krpm and even 2.5krpm. But saying that iv only tried this when my car was a lot lighter due to part stripping of the interior, so the dynamics may be different.
Agree, if car was lightened it would make those figures.
Remember the Avant is heavier than the saloon
Great software btw
Great software btw
MortenJuul
I love the Racelogic system, with the CAN data - you cannot really compare with the "analouge" video measurements, since the needle is 10% off (at least) to the CAN data
I know that the salon is 30kg lighter, but you need to lighten by 337 kg to obtain the needed power / weight ratio
Light RS4 438,00 440,00 1.342,48 3,06502984
power NM Weight needed kg. pr PS to run 7.08 3k > 8k
337,52 Lighten by (kg)
We want pic's of what has meant to be cleaned
Thanks - out of interest Morten what does your maths work out it should be for 447PS/490NM? If you're correct then only thing I can think of is that stretch I used must have had an incline?! Or a slight dip in the middle as that might explain the return runs when I went back up it.
I'm off to Santa Pod on Saturday (if the weather holds) so will use a couple of my runs to test again using the DIS - you can't get any flatter surface than that place...
Back on topic...
I'll chase Jags on the images he took of mine but TBH he said it was pretty clean so will mean FA. What we need is a new volunteer to take up his FREE offer then we can put this blooming thing to bed....
Back on topic...
to get from 8.5 to 7 sec you would need at least 410 wHP or 525+ at the crank
first, that software is nice...the high 8 sec times are about what I would expect since you only started to ramp >2500 rpm
447PS/490NM (361 lb ft)
that is 6.5% HP, but 14% torque increase which seems hard to grasp since displacement and comp ratio was unchanged...
if that torque number is accurate I would expect 7.5-7.8 range
if the HP is correct 8.0 - 8.2 range
Yes please this thread should have been posted once the evidence was all concludedGavla wrote: then we can put this blooming thing to bed....
Finally got around to trying this myself, last weekend.
Did a total of six runs (3 each, on two different stretches).
Times varied between 8.1 > 9.1
How does that seem Arthur ?
My Avant is supposedly down on power but still pulls well (to me).
Ambient temp was about 12-14c. Evening, so a bit moist.
Still have the SS downpipes and 100 cell cats.
(all done on the DIS / buttons... so plenty of room for error)
Sorry for going OT
Sorry for going OT
Thanks Arthur!ArthurPE wrote:first, that software is nice...the high 8 sec times are about what I would expect since you only started to ramp >2500 rpm
Users browsing this forum: No registered users and 190 guests
