Clunking noise ...
Re: Clunking noise ...
...i hope its just nr 5
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
I do to for your sake
...well, took out the driveshaft and looked at the bold nr 5 from the flange axle. unfortunately it wasnt the bold, so its prob a bearing inside the diff
looked in Elsawin, its shown ENGINE OUT jobbie...
Will have a look on the oil level to, cos there are signs of an oilleak.
Strange thing is i dont hear grinding noises, which i think should be there with this kind of play...
Looking at my options atm...
Not happy at all.
Not happy at all.
Yellow Koni's
Yellow Koni's
Can you feel play in the flange? Maybe the diff is dry.
Yes, about 1,5-2mm, in wheel direction and from front to back...Shoppinit wrote:Can you feel play in the flange? Maybe the diff is dry.
Will the right oil level solve the play? Or do you mean cos of possible low oil level its worn?
Yellow Koni's
Yellow Koni's
...was surprised to find out while in ''P'', we still could turn the right driveshaft. is that normal?
Dont know which wheels are blocked when in ''P''.
Yellow Koni's
Yellow Koni's
I. Must. Not. Comment.Shoppinit wrote:Can you feel play in the flange? Maybe the diff is dry.
Two Audi mechanics I know have mentioned this is common wear over time. So im surprised i havent heard of this over here.
So i would recommend:
Play with your flange and be sure theres enough fluid...
Yellow Koni's
Yellow Koni's
*snigger*mavada wrote: Play with your flange and be sure theres enough fluid...
NURSE !!! ..............he's out of his bed againShoppinit wrote:*snigger*mavada wrote: Play with your flange and be sure theres enough fluid...
I could move the car today for about 3-5 cm before i heard a click sound and couldnt move further forward. The same as when in P and move my foot from the brakepedal, it alway goes that distance forward before stopping....it drives fine, just noticed it this morning...mavada wrote:...was surprised to find out while in ''P'', we still could turn the right driveshaft. is that normal?
Probably normal...
Yellow Koni's
Yellow Koni's
Yes, there's loads of play in the drive train. When you put it in P you can still move the car a couple of cm back and forth.
yeah, but much further before i heard the click sound, after that less distance...Shoppinit wrote:Yes, there's loads of play in the drive train. When you put it in P you can still move the car a couple of cm back and forth.
...and while moving back and forth i could feel the flangeaxle's play...
Yellow Koni's
Yellow Koni's
...found another one, no rs6 but same symptoms...
http://s148.photobucket.com/user/Ska_pi ... 7.flv.html
Yellow Koni's
Yellow Koni's
Wow, you can really see the play. Mine didn't have a gnat's hair of play in them.
Users browsing this forum: No registered users and 520 guests
