RS6 Vibration when passing 70mph
Re: RS6 Vibration when passing 70mph
Had a word with the dealer , he freaked out a bit when I told him that Liverpool Audi said that in their opinion the car is unsafe and he is going to pick up the car fixed and bring it back . After that I will go to Unit 20 just for a peace of mind re-check.
Rs6 2004 Grey
That sounds possibly like a Propshaft CV joint that has dried up and has some play.
I had the same thing on my Audi S8. When I pulled the trans out to fix it, I noticed that the front CV joint was as dry as a bone and stiff to move.
Fingers crossed that you get everything fixed at the dealer where you bought the car.
Good luck.
MG
Good luck.
MG
I'd be inclined to put up with a bit of a shudder at 70 , plant the right foot and put it down to the road surface...sounds priceyRS2 wrote:That sounds possibly like a Propshaft CV joint that has dried up and has some play.
Good luck.
MG
Do you ever come on this forum sober?bakustax wrote:I'd be inclined to put up with a bit of a shudder at 70 , plant the right foot and put it down to the road surface...sounds priceyRS2 wrote:That sounds possibly like a Propshaft CV joint that has dried up and has some play.
Good luck.
MG
Brilliant...FON...Skippybam_bam wrote:Do you ever come on this forum sober?bakustax wrote:I'd be inclined to put up with a bit of a shudder at 70 , plant the right foot and put it down to the road surface...sounds priceyRS2 wrote:That sounds possibly like a Propshaft CV joint that has dried up and has some play.
Good luck.
MG
Thanks, mate!bakustax wrote: Brilliant...FON...Skippy
Ahem... I didn't make that very clear did Ibakustax wrote:I'd be inclined to put up with a bit of a shudder at 70 , plant the right foot and put it down to the road surface...sounds priceyRS2 wrote:That sounds possibly like a Propshaft CV joint that has dried up and has some play.
Good luck.
MG
Sorry... I was pulling the trans out to fix the trans... not fix the propshaft!
My apologies. The propshaft is a lot easier to get at. Exhaust off, heat shield off and you're there.
MG
Oh it was very clear to everyone who read it, properly...RS2 wrote: Ahem... I didn't make that very clear did I...
