V-power Nitro+
- esp_mm-270
Re: V-power Nitro+
Lol, wrong way round for valve overlap, that's unburnt fuel air mixture down the exhaust. Soz.
- esp_mm-270
Re: V-power Nitro+
Or just air on an FSI depending on fuel timing on these engines. It'll be on the piston upstroke at some point I would guess, but earlier than a ci engine. I'll look in to it and get back.
Re: V-power Nitro+
this sounds like fun. i want to make barp barp barp wrc style antilag sounds too. Pop bang and flamezzz for extra effectesp_mm-270 wrote:Lol, wrong way round for valve overlap, that's unburnt fuel air mixture down the exhaust. Soz.
Recycling dinosaurs for fun
Re: V-power Nitro+
On a serious note, fuel injection will occur when the exhaust is closed, to prevent unnecessary losses - one of the ways these engines increase efficiency.
Re: V-power Nitro+
So direction injection (as name suggest) never wets the inlet. The inlet just gets hammered by 'zoorst blowby, hence carbon build up?sweegie wrote:On a serious note, fuel injection will occur when the exhaust is closed, to prevent unnecessary losses - one of the ways these engines increase efficiency.
- esp_mm-270
Re: V-power Nitro+
Absolutely. Everywhere I look has a different take on fuel timing. Some say in piston down stroke, some say upstroke and others again say two sprays at different stages, one of which happens at near tdc like a ci engine. I'll ring the designer once I got their number lol.sweegie wrote:On a serious note, fuel injection will occur when the exhaust is closed, to prevent unnecessary losses - one of the ways these engines increase efficiency.
Re: V-power Nitro+
That's my understanding... On non GDI engines, there's always a little fuel left hanging around the inlet valve that aids valve washing. I believe however some manufacturers (toyota maybe?) ended up with a dual system, where a central injector adds fuel to the inlet charge, compounded with DI to add the main fuel mix.bam_bam wrote:So direction injection (as name suggest) never wets the inlet. The inlet just gets hammered by 'zoorst blowby, hence carbon build up?sweegie wrote:On a serious note, fuel injection will occur when the exhaust is closed, to prevent unnecessary losses - one of the ways these engines increase efficiency.
Sounds like a total fud of a system to be honest & I'd wager a coked up GDI engine performs worse overall than a standard system.
Re: V-power Nitro+
Go and tell that to the B7 boys... Don't forget your flak jacket.
Re: V-power Nitro+
They already know their engines are full of cack. Don't need me to tell them they've got more problems than a copy of Womens Weekly.Shoppinit wrote:Go and tell that to the B7 boys... Don't forget your flak jacket.
Re: V-power Nitro+
Some of them are, um how to put it, a little touchy on the subject.
My mate dyno'd his B7 and got 369PS.
Re: V-power Nitro+
...really, he should get a discount on that b7Shoppinit wrote:Some of them are, um how to put it, a little touchy on the subject.
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Re: V-power Nitro+
Yeah, mentioning dyno numbers ALWAYS goes down well... throw in some 3rd gear pull timing and quarter times for the biggest shitstorm ever, the forum will meltdown, again.
Re: V-power Nitro+
Ha ha. Do it !bam_bam wrote:Yeah, mentioning dyno numbers ALWAYS goes down well... throw in some 3rd gear pull timing and quarter times for the biggest shitstorm ever, the forum will meltdown, again.
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
Re: V-power Nitro+
Logs you say? I've got a few after I mapped the car. 45 to 160kph in 3rd gear any use?
/baiting
/baiting
Re: V-power Nitro+
234565434567898765.556
<120mph aero moot
3.14 x RS4 + drivers weight
Stop being passive/aggressive
Tyre rolling resistance
You're all wrong
[/ArthurPE]
<120mph aero moot
You're all wrong
[/ArthurPE]
Users browsing this forum: Steve2003rs6 and 124 guests
