V-power Nitro+
esp_mm-270
Re: V-power Nitro+
Post by esp_mm-270 » Thu Apr 18, 2013 5:01 pm
Lol, wrong way round for valve overlap, that's unburnt fuel air mixture down the exhaust. Soz.
esp_mm-270
Re: V-power Nitro+
Post by esp_mm-270 » Thu Apr 18, 2013 5:07 pm
Or just air on an FSI depending on fuel timing on these engines. It'll be on the piston upstroke at some point I would guess, but earlier than a ci engine. I'll look in to it and get back.
sweegie
Re: V-power Nitro+
Post by sweegie » Thu Apr 18, 2013 5:10 pm
esp_mm-270 wrote:Lol, wrong way round for valve overlap, that's unburnt fuel air mixture down the exhaust. Soz.
this sounds like fun. i want to make barp barp barp wrc style antilag sounds too. Pop bang and flamezzz for extra effect :D
Recycling dinosaurs for fun
sweegie
Re: V-power Nitro+
Post by sweegie » Thu Apr 18, 2013 5:12 pm
On a serious note, fuel injection will occur when the exhaust is closed, to prevent unnecessary losses - one of the ways these engines increase efficiency.
Re: V-power Nitro+
Post by bam_bam » Thu Apr 18, 2013 5:27 pm
sweegie wrote:On a serious note, fuel injection will occur when the exhaust is closed, to prevent unnecessary losses - one of the ways these engines increase efficiency.
So direction injection (as name suggest) never wets the inlet. The inlet just gets hammered by 'zoorst blowby, hence carbon build up?
esp_mm-270
Re: V-power Nitro+
Post by esp_mm-270 » Thu Apr 18, 2013 5:28 pm
Absolutely. Everywhere I look has a different take on fuel timing. Some say in piston down stroke, some say upstroke and others again say two sprays at different stages, one of which happens at near tdc like a ci engine. I'll ring the designer once I got their number lol.
sweegie
Re: V-power Nitro+
Post by sweegie » Thu Apr 18, 2013 5:40 pm
That's my understanding... On non GDI engines, there's always a little fuel left hanging around the inlet valve that aids valve washing. I believe however some manufacturers (toyota maybe?) ended up with a dual system, where a central injector adds fuel to the inlet charge, compounded with DI to add the main fuel mix.
Sounds like a total fud of a system to be honest & I'd wager a coked up GDI engine performs worse overall than a standard system.
Re: V-power Nitro+
Post by Shoppinit » Thu Apr 18, 2013 5:51 pm
Go and tell that to the B7 boys... Don't forget your flak jacket.
sweegie
Re: V-power Nitro+
Post by sweegie » Thu Apr 18, 2013 5:57 pm
Shoppinit wrote:Go and tell that to the B7 boys... Don't forget your flak jacket.
They already know their engines are full of cack. Don't need me to tell them they've got more problems than a copy of Womens Weekly. ;)
Re: V-power Nitro+
Post by Shoppinit » Thu Apr 18, 2013 5:58 pm
Some of them are, um how to put it, a little touchy on the subject. :)
My mate dyno'd his B7 and got 369PS. :drink:
mavada
Re: V-power Nitro+
Post by mavada » Thu Apr 18, 2013 6:24 pm
Shoppinit wrote:Some of them are, um how to put it, a little touchy on the subject. :)
...really, he should get a discount on that b7
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Re: V-power Nitro+
Post by bam_bam » Thu Apr 18, 2013 6:29 pm
Yeah, mentioning dyno numbers ALWAYS goes down well... throw in some 3rd gear pull timing and quarter times for the biggest shitstorm ever, the forum will meltdown, again.
seaneb
Re: V-power Nitro+
Post by seaneb » Thu Apr 18, 2013 9:13 pm
bam_bam wrote:Yeah, mentioning dyno numbers ALWAYS goes down well... throw in some 3rd gear pull timing and quarter times for the biggest shitstorm ever, the forum will meltdown, again.
Ha ha. Do it !
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
sweegie
Re: V-power Nitro+
Post by sweegie » Fri Apr 19, 2013 10:19 am
Logs you say? I've got a few after I mapped the car. 45 to 160kph in 3rd gear any use?
/baiting
Re: V-power Nitro+
Post by bam_bam » Sun Apr 21, 2013 9:50 pm
234565434567898765.556
<120mph aero moot
3.14 x RS4 + drivers weight
Stop being passive/aggressive
Tyre rolling resistance
You're all wrong
[/ArthurPE]
