Any one know the price on the valves in the rs4 wheels
Jamiestanton
Post by Jamiestanton » Tue Mar 12, 2013 11:46 pm
The valves in the rs4 wheels are ones that tell the computer if there flat I have had my wheels refurbed and don't want to pay dealer prices if there £££££££
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
AndyJE
Re: Any one know the price on the valves in the rs4 wheels
Post by AndyJE » Tue Mar 12, 2013 11:58 pm
Yes, I just had all of mine changed at the dealer due to corrosion - they were £13 each + vat, I think...
Madmonkee
Post by Madmonkee » Wed Mar 13, 2013 12:17 am
If its the TPMS sensors we are talking about your looking £75+ each, unless you buy an unknown make from ebay.de
Post by MikeFish » Wed Mar 13, 2013 12:57 am
There is 2 parts, the sensor inside the wheel and the valve that connects to the sensor and it the bit that you connect the pump to, to inflate the tyre. The sensors are quite expensive but can be had on ebay for about £100 odd but be warned they have batteries in them that cannot be replaced once they go flat, so if you buy a set that are 5 years old and the battery dies a week later you need to bin them and buy another set.
The valves are about £20 each on ebay. I bought a set of 4 for £75.
Or you could disable the TPMS using a VCDS cable and go old school and check your tyre pressures manually.
Jamiestanton
Post by Jamiestanton » Wed Mar 13, 2013 6:33 pm
MikeFish wrote:Or you could disable the TPMS using a VCDS cable and go old school and check your tyre pressures manually.
Yeh but can this defo be done if yes I will
adsgreen
Post by adsgreen » Wed Mar 13, 2013 7:08 pm
the sensors (assuming new) don't discharge until they are exposed to a certain pressure (guessing about 15psi).
Thats when the clock starts.
u2usual
Post by u2usual » Wed Mar 13, 2013 7:15 pm
I have an extra set of sensors if someone is interested.
Post by MikeFish » Wed Mar 13, 2013 7:43 pm
Yes, you subtract 512 from the value of channel 61(need to double check the channel number) on the instrument cluster.
PetrolDave
Post by PetrolDave » Wed Mar 13, 2013 8:04 pm
See http://wiki.ross-tech.com/wiki/index.ph ... 8ED/8HE%29
MB2
Post by MB2 » Thu Mar 14, 2013 1:14 pm
adsgreen wrote:the sensors (assuming new) don't discharge until they are exposed to a certain pressure (guessing about 15psi).
I was told they had G sensors in them so are only active when the wheels are in motion, although the battery will clearly have a finite life, a set that has been sitting around even after some use may not be such a bad bet if has been "dormant" most of the time.
adsgreen
Post by adsgreen » Thu Mar 14, 2013 1:34 pm
yes they do but even g sensors need power ;)
Theres a mechanical switch that when the pressure is raised breaks and connects the electronics to the g sensor.
So the storage shelf life is actually really really long... but as soon as they are fitted then you are on a fixed lifespan (give or take).
Now if you could mix in self winding mech from some expensive watches you cuold have ones that neve need changing...
MB2
Post by MB2 » Thu Mar 14, 2013 3:56 pm
Oh that is sophisticated - I assumed the "G Sensor" was just a weight that got spun out & completed the circuit. Given I paid over 600 to service a mechanical watch earlier this year I think our TPMS is better left as disposable technology although to be fair the watch was still keeping time so maybe would be OK in a TPMS !
Users browsing this forum: Majestic-12 [Bot] and 391 guests
