Got me some new wheels
andre3k
Re: Got me some new wheels
Post by andre3k » Tue Jan 15, 2013 11:56 am
Someone did this with an avus cab and it looked awesome. Can't remember his name
Post by MikeFish » Tue Jan 15, 2013 12:27 pm
I have seen comments before about these wheels on an RS4 and they are mixed. Some people like like them but others don't. That doesnt bother me as long as I like them. My missus said to not buy them, she doesnt like them, I know half you guys will think they are wrong and i've seen a lot of comments that only the OEM wheels or the RS6 wheels look any good. I agree the OEM are a good set of wheels but I'm not a fan of the RS6 ones. Each to their own.
Post by MikeFish » Tue Jan 15, 2013 12:32 pm
There's a photo of a B7 and a B5 with the same wheels in this thread:
http://forum.rs246.com/viewtopic.php?f=64&t=99368
sonny
Post by sonny » Tue Jan 15, 2013 7:48 pm
Your speedo will be out, irrc it should be showing more than you are actually doing, not sure how much maybe around 5%?. So be aware when driving past speed cameras.
When i was running 18s with a lower profile my speedo was out by -7%, so speedo 100mph i was actually doing 93mph. Also engine labouring more. Not sure of the engine will have a reverse effect if you have larger rolling diameter or not?
Btw you will kiss good by to handling anyway so you might as well get bags ;) lol
Post by MikeFish » Tue Jan 15, 2013 9:16 pm
sonny wrote:Your speedo will be out, irrc it should be showing more than you are actually doing, not sure how much maybe around 5%?. So be aware when driving past speed cameras.
You mean it will be showing less than what I am doing? Hence the need to be careful of speed cameras?
I figured it is not a big difference; a new tyre has 8mm of tread and you will will typcially wear it down to about 2mm thereby experiencing a change in diameter if 6mm throught the life of the tyre. All I am doing is adding the same difference to a brande new tyre. As the tyre wear down it will become closer to the size of a brand new correct diameter tyre. I woudlnt have closen this, but hey ho, that's what comes with the whells and its close enough (temporarily) until they wear down and I get some 255/30/20 which will be an exact match to the OEM 255/35/19.
However, I didnt realise this would have a negative effect on handling! Why is this?
I figured a lower profile tyre has less side-wall flex during cornering and therefore better road holding. Is this not the case? Clearly I get that the ride will not be as smooth with a lower profile tyre though.
N11LS_J
Post by N11LS_J » Tue Jan 15, 2013 9:20 pm
Mike get it sitting like this!!! :biggrin3:
I think these look quite good as an OEM wheel too
Still needs to be sitting lower to,really pull it off IMO
Instagram : n_i_l_s
Post by MikeFish » Tue Jan 15, 2013 9:24 pm
Hi Niils
Thats one of the photos I saw that helped me decide on which wheels to get. I know RS4s sitting that low is not everyone cup of tea but I think it's 8) 8) 8)
That isn't on air is it? I'm pretty sure you can get that low on coilovers and still be driveable.
ArthurPE
Post by ArthurPE » Tue Jan 15, 2013 9:26 pm
your sidewall will be 3 mm higher on each side, barely noticable
it will decrease the fender-tire gap by 3mm and raise the car by 3mm
does any know if this combo rubs?
spacers F/R 8/10mm
wheen 9x20 ET26
265/30/19
btw, those 5 spokers are really good looking, my new favorites
N11LS_J
Post by N11LS_J » Tue Jan 15, 2013 9:28 pm
I would say it is probably on air, don't see you being able to drive around like that!
Tou should be able to go quite low on coilovers, slightly higher than that pic, but the car does need to sit nicely on those wheels to pull them off IMO, otherwise you may aswel have stuck with OEM wheels or gone for some other 19" options on standard suspension, any thoughts on going for KWs or Bilsteins even?
DO IT... DO IT... DO IT... :rocker:
Instagram : n_i_l_s
Post by MikeFish » Tue Jan 15, 2013 9:39 pm
N11LS_J wrote:I would say it is probably on air, don't see you being able to drive around like that!
Gonna wait and see what it looks like with the wheels on then decide. I've pretty much ruled out air due to lack of boot space so if it needs lowering I will need to look into the non-air side of things in more detail. I like the sound of the KW kit that still uses DRC. I'd like ot avoid a harder ride but we'll see.
Post by MikeFish » Tue Jan 15, 2013 9:41 pm
ArthurPE wrote:your sidewall will be 3 mm higher on each side, barely noticable
spacers F/R 8/10mm
wheen 9x20 ET26
265/30/19
Arthur, I have 8/10mm spacers on at the moment. The new wheels are 9x20 et26 and the new tyres (although not by choice) are 265/30/20. So later this week I will hopefully be able to let you know if it rubs.
PS I assume you mean 20" tyres as you specified a 20" wheel?
Batfinnk
Post by Batfinnk » Tue Jan 15, 2013 9:46 pm
Can't wait to see a picture of your car with them on Mike. I have been toying with the idea of a set of these although only 18's for my S4 and wanted to see a picture of one with them on to get an idea of what they will look like.
Previous car: 2005 S4 B7.
Post by MikeFish » Tue Jan 15, 2013 9:51 pm
Hi Batfinnk
Be warned, the 18s look very different (the ones i hve seen anyway). My wife had a set of 18s on her S3 and with the narrower rim (8" compared to 9") and the higher offset (ET50 comapred to ET26) you completely lose the concave look of them. Side on they will look similar but at an angle they won't dip in at the centre.
Unless of course you can find an 18x9 version with a low offset. I haven't looked so can't say if they exist, it's just the ones i have seen don't look as good in the smaller size. If Audi don;t make them in that size and you really wanted them still I'm sure one of the replica firms will make them.
dickytrickster
Post by dickytrickster » Tue Jan 15, 2013 9:51 pm
MikeFish wrote:Hi Niils
Maybe coilover wound right down for the show!
Shiv ran his very low on coilovers!
I love how the car sits but it would just be so unpractical at that hight.Thats the only reasion ive gone for air
ArthurPE
Post by ArthurPE » Tue Jan 15, 2013 9:53 pm
spacers F/R 8/10mm
wheen 9x20 ET26
265/30/19
thanks, yep 20" tires
Users browsing this forum: No registered users and 332 guests
