Damper Control
- xxx_mojo_xxx
Damper Control
Can someone explain the mechanics behind damper on the S4? Does it use air suspension or some other technique. I've heard its different to what is used on the A7 and A8.
Re: Damper Control
I've read somewhere that the electrickery controls a valve on the shock, so it is different to the TT and R8 magnetic ride unfortunately.
My shocks do crash quite a bit on holes and ruts.
Audi S4 B8, 6mt, 462hp, 539nm, AWE exhaust with AWE resonated DP's, MRC filter
- xxx_mojo_xxx
Re: Damper Control
If its just a valve...£300 (ex. VAT) as an option sounds steep.
Is it any good?
Keen to hear experiences from existing owners and if its worth the bucks...
- gangstarrrrr
Damper Control
I have it and makes a nice difference when I have the wife in the car, on comfort, ride is very smooth. In dynamic, far more aggressive. I'm a fan.
Damper Control
It's worth the money especially as the comfort setting is softer than the standard S4 set up without ADS which is great on crap roads if you have a car riding on 19 inch wheels.
- xxx_mojo_xxx
Re: Damper Control
I guess it doesn't do any of the fancy stuff on the more expensive Audis like maintain the same ride height irrespective of car load or adapt individual shock firmness when turning in?
I have spec'd 19s so the earlier comment helps.
Re: Damper Control
I have it on mine, its nice and soft when put in comfort on the crap roads around here
B8 RS4: Phantom Black
Previous Motors: | AUDI B8 S4 Avant | BMW E92 M3 | BMW E92 335i N55 | AUDI V8 S5 |
