RS6 Flat battery problems, pls help!!!!!
Re: RS6 Flat battery problems, pls help!!!!!
cheers for the good news guys
anyone want to buy a RS6?
I'll give you 50p for it and keep it for spares for mine
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
Throwing in the towel a bit early, there.
Have you looked at measuring block 62 with the engine off?
What happens when you go from no throttle to full throttle?
will have a play tomorrow now, cheers guys
this cars doing my head in, started up this morning, running fine, will plug it in later when i get 5
Yeah, mine did the same when cold, then in a couple of miles or under certain throttle openings, error - EPC light on, no boost.tallpaul1979 wrote:this cars doing my head in, started up this morning, running fine, will plug it in later when i get 5
Wasnt it the throttle fault that made you combat style through the back of the car into the boot to the battery? I would love another story like that
No, that was a dead battery.chunky79 wrote:Wasnt it the throttle fault that made you combat style through the back of the car into the boot to the battery? I would love another story like that
Bam Bam what was your solution?, sounds extremly simular
He put a new TB on.
This.
Shoppinit wrote:He put a new TB on.
hi guys
cause the rs6 has been blocked in at work for the last week i have been running it up every morning, letting get up to temperature bringing up the revs getting the throttle bodies working.
Its been running perfect! unblocked it monday morning and took it out, as soon as i got round the corner the esp light cam on and started playing up again!
could an abs issue be causing my other issues?
abs/esp/maf/ throttle body are all connected. Think the best course of action for you would be to take it to a specialist who will be able to pin point the actual cause.
All the rest of us can do is offer our best educated guess (although if Shop tells you whats wrong I would go with that as he is right 99% of the time), so you might end up changing things that are fine.
My money is on the TB.
Users browsing this forum: ALE-RS6 and 79 guests
