RS6 Flat battery problems, pls help!!!!!
tallpaul1979
Re: RS6 Flat battery problems, pls help!!!!!
Post by tallpaul1979 » Thu Oct 11, 2012 3:25 pm
cheers for the good news guys
tallpaul1979
Post by tallpaul1979 » Thu Oct 11, 2012 3:35 pm
anyone want to buy a RS6?
gingertoss
Post by gingertoss » Thu Oct 11, 2012 3:49 pm
I'll give you 50p for it and keep it for spares for mine :audibash:
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
Post by Shoppinit » Thu Oct 11, 2012 3:52 pm
Throwing in the towel a bit early, there.
Have you looked at measuring block 62 with the engine off?
What happens when you go from no throttle to full throttle?
tallpaul1979
Post by tallpaul1979 » Thu Oct 11, 2012 4:38 pm
will have a play tomorrow now, cheers guys
tallpaul1979
Post by tallpaul1979 » Fri Oct 12, 2012 10:26 am
this cars doing my head in, started up this morning, running fine, will plug it in later when i get 5
Post by bam_bam » Fri Oct 12, 2012 11:38 am
tallpaul1979 wrote:this cars doing my head in, started up this morning, running fine, will plug it in later when i get 5
Yeah, mine did the same when cold, then in a couple of miles or under certain throttle openings, error - EPC light on, no boost.
Post by chunky79 » Fri Oct 12, 2012 1:04 pm
Wasnt it the throttle fault that made you combat style through the back of the car into the boot to the battery? I would love another story like that
Post by bam_bam » Fri Oct 12, 2012 1:38 pm
chunky79 wrote:Wasnt it the throttle fault that made you combat style through the back of the car into the boot to the battery? I would love another story like that
No, that was a dead battery.
tallpaul1979
Post by tallpaul1979 » Sat Oct 13, 2012 9:42 am
Bam Bam what was your solution?, sounds extremly simular
Post by Shoppinit » Sat Oct 13, 2012 9:46 am
He put a new TB on.
Post by bam_bam » Sat Oct 13, 2012 5:06 pm
This.
Shoppinit wrote:He put a new TB on.
tallpaul1979
Post by tallpaul1979 » Thu Nov 01, 2012 12:12 pm
hi guys
cause the rs6 has been blocked in at work for the last week i have been running it up every morning, letting get up to temperature bringing up the revs getting the throttle bodies working.
Its been running perfect! unblocked it monday morning and took it out, as soon as i got round the corner the esp light cam on and started playing up again!
could an abs issue be causing my other issues?
gingertoss
Post by gingertoss » Thu Nov 01, 2012 12:58 pm
abs/esp/maf/ throttle body are all connected. Think the best course of action for you would be to take it to a specialist who will be able to pin point the actual cause.
All the rest of us can do is offer our best educated guess (although if Shop tells you whats wrong I would go with that as he is right 99% of the time), so you might end up changing things that are fine.
Post by bam_bam » Thu Nov 01, 2012 1:13 pm
My money is on the TB.
Users browsing this forum: Google [Bot] and 77 guests
