Itg purchased
- luffenham1
Itg purchased
And it starts.
Just purchased my first and not last upgrade for the beast. A pair of itg filters.
Going to fit them myself over this week in an afternoon. I have heard its a pain in ass to do, but fancy a challenge plus I have a friendly garage just down the road if all goes wrong.
I will try and take photos of each stage as I know a few of you are thinking about these filters and fitting them yourselves.
Just one question, when I change the filters and maybe an JC weld fab exhaust should you remap the car due to different gas pressures going through the system?
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
A6 C6 2.0 tdi Le Mans
RS6 C6 Avant, Monza Silver, Titanium Wheels, ITG Filters
RRS TDV8 ( Silly moment )
B7 RS4 Avant Daytona, R8 oil Cap
B7 S4 Avant, Black
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
Re: Itg purchased
Good stuff
This is my next mod. Even better if you manage to get a write up with pics!!!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Itg purchased
i cant wait for mine to get here this week but cant fit till car is repaird by audi
- luffenham1
Re: Itg purchased
What's up with the car trups ?
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
Re: Itg purchased
- luffenham1
Re: Itg purchased
Wow. I bet that was a bit of a squeaky ass moment. V surprises no damage apart from coolant.
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
Re: Itg purchased
put it this way, im glad i didnt clean the seat this week.
Glad no damage is done, when cleaning all the mud out i have removed the undertray and the coolent looks like its been leaking a while so will see what the tech says.
Trups
Trups
- luffenham1
Re: Itg purchased
Filters Fitted in 45 mins. Not all that hard. Forgot to take photos of each stage but to be honest, their is not much too it.
Might be just me but it sounds slightly different but cant tell if the power is any better. Not that you would notice 5-6 BHP extra in these cars
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
Re: Itg purchased
Good stuff
Can you give us a brief "how too " guide!
What tools needed etc etc
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
- luffenham1
Re: Itg purchased
Here we are chris. A brief guide on how to change your filters plus tools needed for the job
Tools needed
1 flat head screw driver
1 Philips screw driver
1 torque screw driver. Size 30
Socket set.
1. Firstly I got the engine slightly warm. This I was told to help release the rubber around the air intakes.
For the rest of the info I will be working on the left hand side of the car, looking at engine. Just repeat to change the right hand side air filter.
2. Undo the torque screw which is centre left of the engine using the torque driver.
3. Undo the top two clips of the air intake as it enters the head so you can just start to move them. It's can take some time to loosen. Don't completely loosen them only as far as you need to.
4. Next loosen the clip down the bottom of the air intake. I used a socket set for this as it is hard to get to.
5. Using a flat head screw driver prise apart the rubber from the air intake on the bottom end ( near headlight).
6. You can now carefully pull back the rubber and lift up the air intake. The two parts should separate.
7. You cannot completely remove the air intake as their is a third connection which is below the air intake half way up which I could not get to due to no room to work in this engine bay.
You do not have to remove the air intake from the top section. It only need to be loose so the air intake can move slightly.
8. Using a Philips screw driver undo the 4 air filter box screws and disconnect the pipe which comes from the box to a side. It's roughly 1 inch black pipe and unclips by sneezing the two grips on the connection and pulling at the same time. Be careful as this is where I got oil over me.
9. Now with the air intake loose and the air box undone you can lift both enough to get the old filter out and new in.
10. Once changed, tighten up air box, then place the 1 inch pipe back, place the air intake back into the bottom rubber and tighten. Tighten up the top clips on the air intake and replace the torque screw.
You can over tighten these clips so remember how tight they where before undoing them at the start.
Repeat on the right side.
Hay presto , all done
Tools needed
Socket set.
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
Re: Itg purchased
Spot on!! That's what forums like this are all about!!!
Thanks!!
Gonna have a go when my filters come!!
Thanks!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Re: Itg purchased
Did you notice any dirt in the bottom part of the Box?
maybe hover out any Dirt?
thanks for the Guide
i am collecting my BMC ones tomo so will try and do this friday going on this guide.
i am take some pictures going from your guide, if you want il email them to you and you could edit the post?
Trups
Trups
Re: Itg purchased
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
- luffenham1
Re: Itg purchased
No worries Chris. Have fun putting them in.
Yes there was some crap in the bottom but mainly around the edges ( leaves etc ). Got small fingers so got it all out but a vac would be better.
Trups, if you could take some pictures at each stage that would be great and i will edit my post.
Have fun fitting the filters guys.
BMW M5 F10
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
A3 1.4 TFSI (wife)
Previous
B7 S4 Avant, Black
Re: Itg purchased
Just wanted to pass on my thanks to this thread, I've just put some ITG ones on my car, and with your handy guide it took me all of 10mins per side...very easy!
Many thanks!
Mark.
Many thanks!
Mark.
Users browsing this forum: No registered users and 182 guests
