RS4 62-0 braking time?
2.7 V6 30v biturbo - 380 bhp
jukkan
Post by jukkan » Tue Aug 24, 2004 5:06 pm
I found another picture which shows how much there is difference with stock disc and the Movit´s...
Disc comparison stock vs movit
Nordschleife
Post by Nordschleife » Tue Aug 24, 2004 6:05 pm
Most of the high performance Pagid brake pads need braking in ON A REGULAR BASIS. If the noise becomes a problem, discuss alternatives with Guido. Quite a lot of work has been done to cur down on squeal.
R+C
RS4ever
Post by RS4ever » Tue Aug 24, 2004 6:13 pm
Coppaslip between piston and pad. Old fashioned but effective solution to squealing
JAMES
Post by JAMES » Tue Aug 24, 2004 6:32 pm
i thought the movits were 380mm.
are they 4 or 6 pots.
previous: RS2, RS4 2.7, RS4 4.2.
Current: S8 PLUS
jukkan
Post by jukkan » Tue Aug 24, 2004 6:44 pm
they are 4 pots with 370x35mm disc and this is a brand new set -should be better than the 380x34mm set That´s what they told me from Movit!
TarmacTerrorist
Post by TarmacTerrorist » Tue Aug 24, 2004 7:03 pm
James -think they are slightly smaller diameter but are 3mm thicker, 380's are 32mm iirc. Pad contact arae is probably the same, although the callipers look slighty different to the ones they run with the 380's??
Jukkan - Which pads do you have in? If they are Guido's race specials I found that they sqeual really badly until there quite warm. You could afford to run a softer pad on the road as the discs carry the heat away from the pads very well, I currently have pagid blue in and no squealing at all, it also saves you ragging the very expensive discs too quickly.
I just change mine over for track days, 5 minute job once the wheel is off.
Too much is bad.
Plenty is better.
DaveP
Post by DaveP » Tue Aug 24, 2004 8:59 pm
Movit do different sizes of disc depending on what you want....and both 4 and 6 pots (again, depending on what you want/size of your wallet)
6 pot 370mm discs will fit under the standard wheels I've been told - muahahahaa
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
TarmacTerrorist
Post by TarmacTerrorist » Tue Aug 24, 2004 11:19 pm
DaveP wrote:Movit do different sizes of disc depending on what you want....and both 4 and 6 pots (again, depending on what you want/size of your wallet)
Dahlback racing do a very similar kit with the same 6 pot callipers, which from the photos on there website look like they aslo fit under the 18's.
The 380's will apparently fit under the 18 inch winter wheels withno problem or so I'm lead to believe
Too much is bad.
Plenty is better.
