RS4 62-0 braking time?
- 5th Gear
James -think they are slightly smaller diameter but are 3mm thicker, 380's are 32mm iirc. Pad contact arae is probably the same, although the callipers look slighty different to the ones they run with the 380's??
Jukkan - Which pads do you have in? If they are Guido's race specials I found that they sqeual really badly until there quite warm. You could afford to run a softer pad on the road as the discs carry the heat away from the pads very well, I currently have pagid blue in and no squealing at all, it also saves you ragging the very expensive discs too quickly.
I just change mine over for track days, 5 minute job once the wheel is off.
Too much is bad.
Plenty is better.
Plenty is better.
- 5th Gear
Dahlback racing do a very similar kit with the same 6 pot callipers, which from the photos on there website look like they aslo fit under the 18's.DaveP wrote:Movit do different sizes of disc depending on what you want....and both 4 and 6 pots (again, depending on what you want/size of your wallet)
6 pot 370mm discs will fit under the standard wheels I've been told - muahahahaa
The 380's will apparently fit under the 18 inch winter wheels withno problem or so I'm lead to believe
Too much is bad.
Plenty is better.
Plenty is better.
