Shoppinit wrote:
Tell us what the 4 zones say not touching the pedal and full throttle.
RS6 Flat battery problems, pls help!!!!!
Re: RS6 Flat battery problems, pls help!!!!!
Mong²
- Mr Footlong
Que? 62 is shown as requested, there are 4 values to the right of it so not sure what you are saying I haven't given you?
Current:
Gone:
Gone:
The 4 values off throttle. And the 4 values full throttle.
- Mr Footlong
Sorry, misread totally. No chance of that now, work and won't be touching the car really until Friday but thanks.
Current:
Gone:
Gone:
You know the crying shame is that you guys are incredibly knowledgeable...maybe I need to just see past my intolerance of "Aussie humour"...carry on chaps you're doing a fantastic job
Cheers guys, will try another tba today!, will let you know how i get on!
hi
tba seems to work!
the only code thats coming up now is the airbag one
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 P
Component: Airbag 8.4EP 2002
Coding: 0000606
Shop #: WSC 00000 785 00200
VCID: 3D7ACD7E67DA89F00A3
1 Fault Found:
01589 - Igniter for Head-Airbag; Passenger Side (N252)
001 - Upper Limit Exceeded - MIL ON
any ideas how to get rid of this?
and would this make the big ! come up up flashing on the dash and bleeping?
tallpaul1979
tba seems to work!
Coding: 0000606
1 Fault Found:
tallpaul1979
Cool.
Sounds like you've got an airbag fault. Have you done anything in that area recently? Could have come unplugged.
Don't jump the gun on the TBA, it can go pear shaped after getting hot. The air bag thing isn't great as it's getting close to end-of-life.
can you turn the pass airbag off? if so will that get rid of the code?
hi
just went to take it round the block and started up pulled it out of the garage, started spluttering and stalled, tryed starting again and just keeps stalling!
plugged it in and went into basic settings for the tba and noticed: 12.5% throttle sensor1 14.6% throttle sensor 2 result throttle valve adt error
Thursday,11,October,2012,14:33:49:43815
VCDS Version: Release 11.11.4
Address 01: Engine Labels: 077-907-558-BCY.LBL
Control Module Part Number: 4D1 907 558
Component and/or Version: 4.2l V8/5VT G 0004
Software Coding: 0010752
Work Shop Code: WSC 00000 785 00200
VCID: EBDEB326C92E5740647
2 Faults Found:
17966 - Throttle Actuator (G186)
P1558 - 002 - Electrical Malfunction
17987 - Throttle Actuator (J338)
P1579 - 001 - Adaptation Not Started
Readiness: 0110 1101
So back to square one again
any ideas people
2 Faults Found:
any ideas people
- Mr Footlong
I don't believe that you can disable the passenger side airbags. There is certainly nothing obvious I have seen as in a physical switch/key turn enable/disable feature as you see on Clios etc.tallpaul1979 wrote:can you turn the pass airbag off? if so will that get rid of the code?
Current:
Gone:
Gone:
TB is toast. You can try TBA again but I've just been through this, it would run ok then fuk up again once hot or stall at start up.tallpaul1979 wrote:hi
2 Faults Found:
any ideas people
Think your throttle body might be borked.
Users browsing this forum: srichards and 82 guests
