RS6 Flat battery problems, pls help!!!!!
Re: RS6 Flat battery problems, pls help!!!!!
Post by Shoppinit » Tue Oct 09, 2012 4:13 pm
Mong²
Shoppinit wrote:
Tell us what the 4 zones say not touching the pedal and full throttle.
Mr Footlong
Post by Mr Footlong » Tue Oct 09, 2012 4:18 pm
Que? 62 is shown as requested, there are 4 values to the right of it so not sure what you are saying I haven't given you?
Current:
Gone:
Post by Shoppinit » Tue Oct 09, 2012 4:21 pm
The 4 values off throttle. And the 4 values full throttle.
Mr Footlong
Post by Mr Footlong » Tue Oct 09, 2012 4:27 pm
Sorry, misread totally. No chance of that now, work and won't be touching the car really until Friday but thanks.
Current:
Gone:
bakustax
Post by bakustax » Tue Oct 09, 2012 6:25 pm
You know the crying shame is that you guys are incredibly knowledgeable...maybe I need to just see past my intolerance of "Aussie humour"...carry on chaps you're doing a fantastic job :thumbs:
tallpaul1979
Post by tallpaul1979 » Thu Oct 11, 2012 9:17 am
Cheers guys, will try another tba today!, will let you know how i get on!
tallpaul1979
Post by tallpaul1979 » Thu Oct 11, 2012 10:30 am
hi
tba seems to work!
the only code thats coming up now is the airbag one
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 P
Component: Airbag 8.4EP 2002
Coding: 0000606
Shop #: WSC 00000 785 00200
VCID: 3D7ACD7E67DA89F00A3
1 Fault Found:
01589 - Igniter for Head-Airbag; Passenger Side (N252)
001 - Upper Limit Exceeded - MIL ON
any ideas how to get rid of this?
and would this make the big ! come up up flashing on the dash and bleeping?
tallpaul1979
Post by Shoppinit » Thu Oct 11, 2012 10:34 am
Cool.
Sounds like you've got an airbag fault. Have you done anything in that area recently? Could have come unplugged.
Post by bam_bam » Thu Oct 11, 2012 10:37 am
Don't jump the gun on the TBA, it can go pear shaped after getting hot. The air bag thing isn't great as it's getting close to end-of-life.
tallpaul1979
Post by tallpaul1979 » Thu Oct 11, 2012 10:37 am
can you turn the pass airbag off? if so will that get rid of the code?
tallpaul1979
Post by tallpaul1979 » Thu Oct 11, 2012 2:55 pm
hi
just went to take it round the block and started up pulled it out of the garage, started spluttering and stalled, tryed starting again and just keeps stalling!
plugged it in and went into basic settings for the tba and noticed: 12.5% throttle sensor1 14.6% throttle sensor 2 result throttle valve adt error
Thursday,11,October,2012,14:33:49:43815
VCDS Version: Release 11.11.4
Address 01: Engine Labels: 077-907-558-BCY.LBL
Control Module Part Number: 4D1 907 558
Component and/or Version: 4.2l V8/5VT G 0004
Software Coding: 0010752
Work Shop Code: WSC 00000 785 00200
VCID: EBDEB326C92E5740647
2 Faults Found:
17966 - Throttle Actuator (G186)
P1558 - 002 - Electrical Malfunction
17987 - Throttle Actuator (J338)
P1579 - 001 - Adaptation Not Started
Readiness: 0110 1101
So back to square one again
any ideas people
Mr Footlong
Post by Mr Footlong » Thu Oct 11, 2012 3:05 pm
tallpaul1979 wrote:can you turn the pass airbag off? if so will that get rid of the code?
I don't believe that you can disable the passenger side airbags. There is certainly nothing obvious I have seen as in a physical switch/key turn enable/disable feature as you see on Clios etc.
Current:
Gone:
Post by bam_bam » Thu Oct 11, 2012 3:12 pm
tallpaul1979 wrote:hi
2 Faults Found:
any ideas people
TB is toast. You can try TBA again but I've just been through this, it would run ok then fuk up again once hot or stall at start up.
Post by Shoppinit » Thu Oct 11, 2012 3:14 pm
Think your throttle body might be borked.
Post by bam_bam » Thu Oct 11, 2012 3:15 pm
Haha, borked.
Users browsing this forum: Shoppinit, srichards and 80 guests
