Shell VPower thoughts.....
I run my S4 on 95 as it's mapped for it but might try a couple of tanks of super to see if the mpg or performance improves.
Re: Shell VPower thoughts.....
Let me know how you get on Paul. How you enjoying the motor anyway?
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
Will do mate and yes I'm really enjoying it.
- PetrolDave
The bizarre thing is that because super unleaded (jn the UK at least) has a lower sulphur content it "poisons" the pre-cats more slowly so they need purging less often - and purging them is done by richening the mixture and adjusting the timing to raise the exhaust gas temperature, which increases the fuel consumption.gilford wrote:You've just dumped £40k on a car and you're going to quibble over a few pence on petrol, the mind boggles with some of you lot
The result?
Running on petrol with a lower sulphur content increases mpg by around 10%, which more than offsets the higher cost per litre of super unleaded which is about 6%. So because super unleaded has a lower sulphur content it costs LESS per mile than normal unleaded. Strange, but true...
I use Tesco99 or Shell V-Power whenever possible. I will use 95 RON at a push but I had a car engine blow up on me (Impreza Turbo) because I regularly used 95 (which the filler cap said was fine) when I should have been using Super.
How can you put that down to the fuel grade?
V power for me as the shell garage is 1/4 mile from the house. Did get stuck on Saturday low on petrol so had to use normal just to get me home. (we all know a score doesn't last long in an RS4
RS4 Avant - Misano Red
I had a 1998 impreza turbo that was mapped for 95 fuel however import wrx imprezas were mapped for at least 98 and a lot of owners were using an octane booster to prevent knock.
I had an Octavia vrs before I changed to my S4 and that was meant to run better on 98 but I got sick of paying extra for super unleaded for no obvious improvement in performance or economy so ran it for a year on 95 unleaded - could not tell the difference.
Page 133 of my manual - "Super Plus petrol (98-RON) is recommended"
I always stick with Tesco Momentum and Shell V-Power (both 99 RON I think)
Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012.
- Dave_Hedgehog
- 5th Gear
UK RS3s have a 98Ron map, its listed on the spec sheet for the car as a separate item (i have mine somewhere from the dealer), the map can run on 95ron and probably wont do any harmD_K wrote:obviously T99 ... but that was mapped for 99RONbam_bam wrote:Ahuh... and what did you run in the C6 5.0TT?D_K wrote:Iv used 95 on my TTRS's no issue
I think the stock 2.5TFSI is mapped for 95RON
but i only use 99 in the R8
audi quote 320bhp for the RS3? but the couple i have seen dyno'd running on SUL have dyno'd at around 350bhp
The Hedgehog, creator of RS4.org, back in of the RS fold yet again, third time lucky
I reckon the above states says more about how you feel about the cars, DK.D_K wrote:I think the stock 2.5TFSI is mapped for 95RONbam_bam wrote:Ahuh... and what did you run in the C6 5.0TT?D_K wrote:Iv used 95 on my TTRS's no issue
Girl's car = Meh, fill it with 95RON or put some cat pi$$, bothered.
Man's car = Fill it up with some Hennessy XO Cognac, please my dear station keeper.
I thought the RS6 C6 was a diesel, so I run mine on chip fat
I'm no expert: it was something to do with knocking and carbon build up, I seem to recall.Nickyboy wrote:How can you put that down to the fuel grade?
I may stick more with the Shell V-Power now after reading this
http://www.vxronline.co.uk/forum/showth ... -99/page12
- Dave_Hedgehog
- 5th Gear
JonG wrote:I may stick more with the Shell V-Power now after reading this![]()
from what i can see a tuner/racer says dont use tesco 99, after loosing BTCC sponsorship but will not provide any substantiating facts
and you then get this post
Hi
We are a tuning company who recommend Tesco Momentum 99 fuel because it improves performance and fuel economy. This is especially obvious with higher powered/ tuned vehicles.
We were sponsored by Tesco last year but this was not continued in 2012. However this would not effect my judgement or opinion on their fuel.
We have never had any problems or failures related to Tesco Momentum 99 fuel and will continue to recommend this and Shell V Power.
Regards
Ian R Matthews
AmDTuning.com
Users browsing this forum: No registered users and 9 guests
