Forge DV
PhilT
RS246.com
Forge DV
Post by PhilT » Thu Feb 27, 2003 12:06 pm
As some of you may know, my day at Donnington yesterday was troubled by intermittent/lack of boost. There were a couple of reasons for this, the first being a split vacuum pipe (the braided one) and the second the Forge diverters.
It appears that I was running the earlier version of the diverters. The only way to tell is to take the diverter apart and check for a seal around the top of the thread (I wish I had taken pictures!!). The new valves have three seals, two for the piston, and one for the case itself; the 'old' ones have two seals for the piston, and no seal for the case.
The second problem was the spring inside the diverter. There are three types of spring - green, yellow, and red - Green is the weakest and red the strongest. I was running green springs.
The end result was that I drove straight to Revo and they swapped my 'old' DVs for the new ones which I fitted in combination with the red springs. I now have a set of each of the springs as the choice of spring is down to the driver, and I can change them if I am not happy.
The car is performing much better now.
Forge UK can be found at http://www.forgemotorsport.co.uk/ and contacted on +44 1452 380999.
Forge US can be found at http://www.forgemotorsport.com/ and contact details are at http://www.forgemotorsport.com/contact.asp.
Bushy
Re: Forge DV
Post by Bushy » Thu Feb 27, 2003 1:57 pm
AmD suggested that i do not fit the red springs as the boost being held for too long could split a hose
Which BTW is what happened yesterday to me anyway
And thanks to Wayside Audi who repaired it on the way home [img]images/graemlins/thumbs.gif[/img]
Can't beat a bit of boost!
PhilT
RS246.com
Re: Forge DV
Post by PhilT » Thu Feb 27, 2003 1:59 pm
I thought you said you were running the yellow springs [img]images/graemlins/tongue.gif[/img] .
Was it the braided hose? What about the error code?
Dean
Re: Forge DV *DELETED*
Post by Dean » Thu Feb 27, 2003 4:04 pm
Post deleted by PhilT
Bushy
Re: Forge DV
Post by Bushy » Thu Feb 27, 2003 4:19 pm
wot post?
not it was one of the larger pieces of pipe from the turbos
Dean
Re: Forge DV
Post by Dean » Thu Feb 27, 2003 6:36 pm
It was me harping on about RS6 Dv in my S3 again, cant be arsed to retype it
I must have not pressed the post button or something
just said that there isn't much point in aftermarket DV's in my opinion
My RS6 Dv was 12 quid...
and looks like the original [img]images/graemlins/smile.gif[/img]
Paul-RS3
Re: Forge DV
Post by Paul-RS3 » Thu Feb 27, 2003 7:11 pm
Dean you posted it in the Stratmosphere Post...
HERE
PhilT
RS246.com
Re: Forge DV
Post by PhilT » Thu Feb 27, 2003 10:29 pm
So now I am I hear there are four types of spring. Weakest to strongest, here they are:
Green
Yellow
Blue
Red
I'm led to believe that the red ones will cope with up to around 2 bar.
LittleSkull
Re: Forge DV
Post by LittleSkull » Fri Feb 28, 2003 4:08 pm
Forge just sent me this for those who want to check out the state of their DV
http://www.forgemotorsport.co.uk/valve_service.pdf
Users browsing this forum: No registered users and 20 guests
