Clutch problem...
ArthurPE
Re: Clutch problem...
Post by ArthurPE » Mon Jul 23, 2012 9:56 pm
vestax32 wrote:Have you had the input shaft guide sleeve done?
ArthurPE wrote:
vestax32 wrote:I have spoken to someone at MRC and he hadn't heard of the guide sleeve problem, but has changed lots of clutch return pipes (Part No. 8E0721465) for the same problem and this seems to cure it. As this is an easyish job I will try this first then go to the input shaft guide sleeve if it doesn't work.
I had the hose changed by the dealer
also new slave
fluid flushed
and heat shield/sleeve on the line
still happens, a bit less, but repeatable
if I rev the engine in neutral a few times, it will do it
no, not worth it until I do the clutch, which with70 miles shouldn't be for a while
when I do I will make sure to inspect the guide to see which type I have and make sure I get the newer part
vestax32
Post by vestax32 » Sat Jul 28, 2012 2:26 pm
So I have picked up the replacement clutch return pipe (8E0721465) pictured, which I am going to get fitted next week. Am I right in saying that the new part has a metal pipe, and the old part has a plastic pipe? Is this visible to the naked eye, or is the old pipe still metal, but internals have changed? Trying to find out, as if I get the car on the ramp and it already has the metal clutch return pipe then there is no point in doing the job?! Advice much appreciated.......
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
Madmonkee
Clutch problem...
Post by Madmonkee » Sat Jul 28, 2012 10:20 pm
Interested in this^^^ is this a hydraulic return pipe? Or is there a cable that runs inside?
ArthurPE
Post by ArthurPE » Sat Jul 28, 2012 10:42 pm
I had mine replaced
small steel line plugs into slave (similar to yours) connected ~10" of rubber hose (some think this is the problem, collapses and inhibits return) connected to another 12" of stteel to the master
that piece on mine is steel, slightly different shape
I am going to run a test
car warmed up
depress clutch and rev engine a few times, see if I get the isse, sticky, pedal stays down
then let it cool for a minute
do with the pedal out, rev it a few times, then see if I get the issue
if I only get it when depressed (release bearing out on busshing) seems to indicate it is the bushing
added a pic, hose oriented to connect to the slave, the silver tubing is the heat sleeving I had the dealer put on
ArthurPE
Post by ArthurPE » Sat Jul 28, 2012 10:53 pm
is the tube screwed into or pressed into the fitting/bushing?
is that a spring-clip on the busshing? is there a ball and spring in it? or just open?
looked at my receipt
they put on
8E1721465BK (the whole hose)
8E0721465 (the nipple section you got)
did not fix it
http://www.jimellisaudiparts.com/showAs ... bly=752969
items 26 and 26A (at the bottom)
ArthurPE
Post by ArthurPE » Sat Jul 28, 2012 11:20 pm
looked in the box they returned the old parts in (I had H&R springs installed during the DRC recall and had the hose done)
I have that part you have
the hose pops into it, and it into the slave
the spring clip is missing, but the hose and the piece you got both have pop in fittings
so it appears the old and replacement part are the same, and both are steel
Users browsing this forum: No registered users and 151 guests
